Today at 6:48 am by Michael B.
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Slow return to idle after rev
Post  endrnet on Sun Apr 25, 2010 4:29 pm
Title says it all. Idles normal, but after a quick rev it doesn't come down right away. More like after 5 seconds it starts to lower RPM, but doesn't go all the way back to startup/idle RPM.
Some things I'm suspecting:
1) PCM needs time to learn the motor?
2) Lack of VSS signal confusing PCM?
3) Bad (brand new) IAC?
4) I need to let it reach full operating temp?
Dunno the RPMs involved yet, still need to find the tach signal wire without ripping the dash out.
endrnet
Re: Slow return to idle after rev
Post  Admin on Sun Apr 25, 2010 5:43 pm
Tach wire is behind the gauge cluster, just get it!
As far as the RPM problem, is that happening at a standing rev, or while you are driving?
If it happens while driving and coming to a stop, it's the missing VSS. The ecu has to know if the car is moving or not. It's just confused!
It if is happening at a standing rev , could be a stuck PVC, but more likely a possible vacuum leak.
Post  endrnet on Sun Apr 25, 2010 6:28 pm
It's happening at a standstill, not quite ready to set it down on wheels, indeed there are no front wheels right now.
The gauge cluster is not a friendly place, how much of it do I have to tear apart? Does the whole dash have to basically come out?
endrnet
Post  Admin on Sun Apr 25, 2010 8:04 pm
It's a 15 or 20 minute just at the most. Just pull the steering wheel, pull the gauge surround and then pull the four screws that hold in the cluster. pull out on the cluster and tap onto the wire and your done.
Post  endrnet on Sun Apr 25, 2010 8:24 pm
Ah that WAS quick. So this the right lug? (red circle)
endrnet
