Build Update
Build Update
My track project is still "in progress". Here are a few updated pictures. Other than the obvious...I'm waiting on my computer to be re-flashed, wheels to be painted (9x17 twists all the way around), and hood to be repaired/painted.
968gene- Posts : 259
Re: Build Update
That is coming right along. How much longer until is comes to a track near you?
Update
How long? My job keeps getting in the way of my hobby! After the car is together I'll need to find somewhere (dyno) to dial in the computer. I'd like to makeCMP or Roebling in May.
Re: Build Update
I like the color, looks great. Did you fabricate the cage yourself?
Luke714- Posts : 441
Re: Build Update
Atlanta Chassis Dyno
Covington, GA
About an hour SE of Atlanta.
_______________________________________________________
3SX Performance
4317 Triple Crown Drive
Concord NC
Less than an hour from you, Gene.
As low as $80 a pull...
Covington, GA
3SX Performance
Concord NC
gt1scca- Posts : 795
Build Update
The cage was done by Camtech in Charleston, SC (very high quality work).
Thanks Greg. I'll check out 3SX.
Re: Build Update
I have been on both of those tracks, but not in a car. Did they repave Roebling? That pavement was so rough I bottomed my suspension and pulled off line thinking someone had hit me from behind. How is it you have such a nice uncracked dash in a racecar?
Re: Build Update
Do you still have your other dash setup? Most of my plastic switches are dry rotted and wont move. Just curious.
