v8carreragts conversion - Page 4 EmptyYesterday at 2:55 pm by Porsche951toLS3
» Intake Piping For Very Tight Clearances?
v8carreragts conversion - Page 4 EmptyYesterday at 2:46 pm by MotoRider42HC
» WTB: LS Swapped 944
v8carreragts conversion - Page 4 EmptyYesterday at 1:16 pm by porschekid7
» tips on removing headers?
v8carreragts conversion - Page 4 EmptySun Jun 23, 2019 8:57 pm by Worryless
» Lighten clutch pedal feel?
v8carreragts conversion - Page 4 EmptySun Jun 23, 2019 8:44 pm by Worryless
» Torque Tube Heat - What is Normal?
v8carreragts conversion - Page 4 EmptyWed Jun 19, 2019 12:14 pm by superman22x
» FOR SALE: Kokeln Dual Master Bracket
v8carreragts conversion - Page 4 EmptyWed Jun 19, 2019 12:13 pm by MotoRider42HC
» Replacement Radiator
v8carreragts conversion - Page 4 EmptyWed Jun 19, 2019 11:20 am by Hotrodz of Dallas
» ISO ls swap done with working AC :)
v8carreragts conversion - Page 4 EmptyWed Jun 19, 2019 8:19 am by stilov
» 1987 Porsche 944 S - Transaxle FOR SALE
v8carreragts conversion - Page 4 EmptyFri Jun 14, 2019 7:04 pm by MotoRider42HC
June 2019
3456789
10111213141516
17181920212223
24252627282930
Page 4 of 4 Previous  1, 2, 3, 4
v8carreragts conversion - Page 4 Empty Re: v8carreragts conversion
Post  kevin924kevin on Wed Jun 07, 2017 12:07 pm
Thank you for the info. Can i ask you take a pic of the fire wall area. Just want to compare to mine. Thank you again.
Post  v8carreragts on Wed Jun 07, 2017 7:41 pm
Here you go:
If you look close you will see the angle I used to go between the clutch master cylinder bolt and the strut tower.
Post  kevin924kevin on Fri Jun 09, 2017 8:13 am
Thanks again for the pics. Very much appreciated.
Post  matty89 on Sun Jun 11, 2017 3:32 pm
is ur gas tank fumes atmospheric?
matty89
Post  Red944ls1 on Thu Jun 29, 2017 6:49 am
I am adding the BMW system too. What fluid are you using for yours also where did you mount your reservoir. Did you use the turn one pump or stock?
Red944ls1
