v8carreragts conversion
+15
pa951
racertomtom
RS Technic
HorizonblueDK
thom
turbobob924
19 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: v8carreragts conversion
Nice work...I'm betting that dash cap will last a VERY long time too.
944convert- Posts : 253
Finished my headers today. Now I need to get them ceramic coated. These are 1 3/4 tube and 3 1/2 collectors with 3/8 flanges.
v8carreragts- Posts : 332
Those look great, the whole project is sweet. Where did you get the polycarbonate for the gauges?
I got the polycarbonate from McMaster Carr and cut them out.
Longtime no talk to
I'm hoping to get my car back on the road this year too
Too many other issues lately tough
I have progressed somewhat lately. I found enough money to get the fuel injection on the car so no carb. I bought a FAST EZ-EFI Retrofit systrem and have the manifold pretty much done. I was also able to make up an accelerator cable using Camaro and Porsche parts.
I have the body mostly assembled to start bodywork.
I also gut lucky and found a pair of very nice early 923 Euro front turn signal lenses that are correct for a GT/GTS.
I got the headers ceramic coated and on the car.
I finished installing the fuel filler and all of the hoses. I needed a new rubber boot for the body to filler neck and was able to get one from Germany through Pelican Parts. I need ign. wires, oil cooler lines and install the body wiring harness and I can fire it up.
LT1 intake manifold on pre 1986 heads, that looks quite nice. I guess that's only possible because it's a setup from FAST EZ-EFI.
HorizonblueDK- Posts : 42
Simply awesome, the Carrera script on the valve covers is so cool!
It runs..... Started it this afternoon. The sound quality isn't very good as I took this with my GE digital camera. It's probably time to get a real digital video recorder. In person with open headers it sounds like a pro-stock. This is the first time this car has had a running engine in almost 15 years.
v8carreragts wrote:This is the first time this car has had a running engine in almost 15 years.
Sounds great...also sounds like my project...cruising along at a glacial pace... Â
I've accomplished a bit lately.
It is on the ground for the first time. I found that i will need to adjust the rear height.
Installed the flush windshield
made up 924 Carrera GTShood latches- still have some work to do here
The flush windshield looks great.
Could you update:
with your experience, hints, suggestions etc. Many thanks.
Could you update:
Started painting. The color is Blood Orange/Tangerine code 016 or L21E
[URL=https://s993.photobucket.com/user/petetjjj/media/DSC_1971_zps9c88965a.jpg.html][You must be registered and logged in to see this image.]
[URL=https://s993.photobucket.com/user/petetjjj/media/DSC_1976_zps35bffc12.jpg.html][You must be registered and logged in to see this image.]
[URL=https://s993.photobucket.com/user/petetjjj/media/DSC_1977_zpsec7fc9e2.jpg.html][You must be registered and logged in to see this image.]
[URL=https://s993.photobucket.com/user/petetjjj/media/DSC_1979_zps9f003b7b.jpg.html][You must be registered and logged in to see this image.]
Nice, I am of course a fan of orange cars
Finally in color! I need to put the decals on the body before I clear coat it.
Looking great Pete.
Love the rear fenders, I had those on my 968-powered 924s.
Clearcoated! I need to color sand and buff it yet.
Wow! That looks great!
Can't wait to see it back together.
RS Technic- Posts : 73
Orange
Your car looks fantastic. Love the orange.
kevin924kevin- Posts : 927
Moved it out of the garage on it's own power!
I didn't take it for a test drive because I needed to adjust the hydraulic T/O bearing. The clutch was grabbing at the floor. Now that that is fixed it has been reining here every day.
Just gorgeous! I bet it drives better than it looks.
Looks Fantastic Pete!
Did you make a booth?
» JP's LS1 Conversion
» Looking to do a LS2 conversion but don't now which kit to use?
» Anyone using a GTO motor?
Page 2 of 4
