» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Oil Pressure Sending Unit
Page 2 of 2 Previous  1, 2
Re: Oil Pressure Sending Unit
Post  robstah on Tue Mar 01, 2011 12:58 am
I see it now. Embarassed
Stupid knock sensor wire was hiding it.
So, what is everyone running for sensor wise (oil pressure + coolant temp for dash)? How important is it that the ECM knows oil pressure? It won't trigger a CEL without it, will it? I am not sure if it was programmed out on my end.
Post  Admin on Tue Mar 01, 2011 1:56 pm
The sensor on the back of the block only goes to the gauge. The ECU does not see oil pressure! Shocked
Post  robstah on Tue Mar 01, 2011 2:46 pm
Admin wrote:The sensor on the back of the block only goes to the gauge. The ECU does not see oil pressure! Shocked
Ah, gotcha. I have yet to look over the ECM wiring let alone touch it and I have dealt with cars that like oil pressures. Razz
Post  Bluemach1 on Tue Mar 01, 2011 9:03 pm
I ended up getting a remote oil filter mount that had extra ports for this exact purpose. That way the original stays where it should and you can connect it to the PCM if you want (IIRC). I still havent installed my motor yet.
I got it off of ebay. Cant remember who the seller was.
I got this idea from XSCHOP. Hopefully he will shime in here...
Bluemach1
Post  xschop on Tue Mar 01, 2011 9:25 pm
this set.....
Oil Pressure adaptor
Post  fliermike45 on Wed Mar 02, 2011 7:52 pm
Here is the Street Performance Oil pressure adaptor.
This version allows you to use the existing device that's behind the intake manifold and also use a
1/8" sensor that's specified in Sloan's manual.
Post  robstah on Wed Mar 02, 2011 8:11 pm
But why run the stock one? If it's sole purpose was for the dash gauge, then we don't need it anymore.
Learning
Post  fliermike45 on Wed Mar 02, 2011 8:20 pm
Always ready to learn something new.
Actually my engine had a oil temp sender in the bat wing oil pan, guess it can go in the adaptor.
Last edited by fliermike45 on Wed Mar 02, 2011 8:26 pm; edited 1 time in total (Reason for editing : Oil temp sender.)
Post  robstah on Sat Mar 05, 2011 12:49 am
I noticed that the VDO 360-009 oil sender is available at egauges.com for 25 dollars. They also have a 1/8 27NPT female to M16 x 1.5 male adapter, so I am going to try that out to see if I can fit the sender behind the intake. Worst case is I move that sender elsewhere or get that T adapter that Mike posted.
Post  Admin on Sat Mar 05, 2011 8:38 am
You will need to put a 90 degree fitting on the sending unit to get it to fit in the original location, it won't fit standing straight up.
Post  robstah on Mon Mar 14, 2011 7:37 pm
It fits, just it's a very tight fit. Plus, you have the bolt getting in the way. You can either add a spacer to the 1/8th NPT, or change that rear bolt out for a hex style/shorter head style bolt.
Post  WillSoz on Fri Mar 18, 2011 1:17 pm
Finally got my adapter in place. It will fit in stock location without changing anything. As mentioned, it is quite tight though. I had to take off my intake manifold, mount the adapter/sender, then re-install the intake. Luckily I am still in the middle of the build so not too much of an issue. I put a couple pics in my gallery to show the adapter, and fitment. The shots are kind of crappy from my phone...
WillSoz
