Instrument question
Instrument question
My 88 944 Instrument cluster has a problem, Speedometer works OK but the odometer and trip do not work. Rev Counter does not work, what's common here??? Fuel/temp/oil and volts all work OK.
Everything did work OK at the completion of the swap.
Pressing tho odometer reset causes the odometer digits to twitch.
Re: Instrument question
My odo and trip are the same. It's a common problem with the little plastic gears in there. I bought a replacement gear but have yet to take things apart and try to fix it.
I replaced the gear in my 86. the hardest part was being careful with the old plastic parts. Clark's garage pretty much explains it as it happens. Make sure the reset pad goes back in the same spot. The reset button in vent hits a pad behind the vent and a push rod resets the odometer electrically. My gear was mush a hard plastic gear over time turns soft and the opposing gear eats it also you are not to reset the odometer unless you are stopped.
gdopnt- Posts : 127
Odometer gear
I fixed my speedometer today and followed the Clarkes elect-09 instructions.
My gear was in two pieces and had gone very soft.
» INSTRUMENT CLUSTER
» FOR SALE - 1987 Turbos with Corvette LS1 - Black
» SPEC stage one flywheel/PP/disc for sale SOLD
