interior removal
interior removal
Hey guys,
So I finally got some more time to swap interiors of my cars, I am stuck on the A-pillars though. I removed the screws and managed to get the bottom loose but I still can not get the top part loose so I can remove the Head liner properly.
Any ideas?
Collin
Any ideas?
Collin
Re: interior removal
You need to remove all the trim around the top (where the light is and sun visors). To remove the headliner you will need to remove all roof trim as well as the sunroof weatherstripping.
Dawgz83948- Posts : 603
Already have all the trim out, all that is there now is the a-pillar piece and the head liner. I can rock the bottom back and forth on pivot around the top but there is not screw holding it. Is there a metal clip holding it in?
Well you've probably already figured it out by now, but the top screw in the A-pillar cover is at a different angle than the lower two. To remove/install the top screw you will need to hold your #2 Phillips screwdriver perfectly vertical as you insert it in the hole, then fish around for the head of the screw. Also, a small pick and a flashlight might help you find the screw head.
This screw is a PITA and the first time I tried to remove the A-pillar cover, I got so frustrated that I drilled out the hole and destroyed the cover. After removing several A-pillar covers, I can now remove this screw with my eyes closed, which I have found is actually better since you can't see the f-ing screw anyway!
ALFAPU- Posts : 59
