» Transaxle rebuild
» Tpc LS adapter plate
Camaro Vs Corvette accessories... what is compatible for the LT1 swap
Post  subterfuge on Wed Mar 31, 2010 2:15 pm
I was going to put this in my other thread, but I think it is different enough to warrant its own:
It looks camaros are ideal for complete pull outs, but if I get an engine for a vette, which of the accessories/parts will work, and which will I need to source from a camaro? Can I use the vette pcm and harness? AC compressor? Alternator? Smog pump? No PS, but what else am I missing? I am looking at a plain vette 4 bolt main, but I can probably get some accessories and other stuff thrown in for a bit more, so I am wondering what else I should work into the deal, and what else I'll have to find separately.
subterfuge
Re: Camaro Vs Corvette accessories... what is compatible for the LT1 swap
Post  Dawgz83948 on Wed Mar 31, 2010 2:41 pm
Only F Body accessories will work. Smog pump and PCM and Wiring are compatible as are the SMOG/EGR tubes. Those are a must for the Pacesetter Headers that are compatable with Cali Emissions.
Post  subterfuge on Wed Mar 31, 2010 2:53 pm
"Smog pump and PCM and Wiring are compatible as are the SMOG/EGR tubes."
Thanks, Tim, I'll see if I can get that stuff thrown in, and start looking at what else i'll need. Are there any specific brackets/mounts for the F body cars, or do the different accs just bolt up to the engine?
subterfuge
Post  Dawgz83948 on Wed Mar 31, 2010 3:28 pm
It depends really. If you only plan on running the Alternator there are kits available that will only fit the alternator. If you are going to run PS and/or A/C then you need the accessory bracket as well as a Buicl Century V6 alternator and the bracket will need to be modified. What year Vette motor?
BTW Stock Vette manifolds do NOT work with a) the 944 or b) the F body A/c Compressor.
Post  subterfuge on Wed Mar 31, 2010 3:38 pm
It is a '94. I will be running the alternator and AC only- though the AC can (and probably will) come later, I'd like to make all the allowances I can for it the first time through. If I plan on using the pacesetter headers, the manifolds shouldn't matter, right?
subterfuge
Post  Dawgz83948 on Wed Mar 31, 2010 4:56 pm
The manifolds will not bolt up and you will need the F Body Compressor and bracket then.
Post  subterfuge on Wed Mar 31, 2010 5:01 pm
OK, I'll get the F body bracket and comp when I'm ready to go to AC, but to get things going I won't worry about it. My priority needs to be getting th BAR sticker first, then I can worry about the gravy later. Thanks Tim.
subterfuge
Post  kelleysj on Wed Apr 28, 2010 5:56 am
where can i find the accessory bracket and is it for the y or f body?
kelleysj
Post  Admin on Wed Apr 28, 2010 7:20 am
Ebay and Craigslist are a good place to start. If you can't find them there I might be able to get them for you, I have a guy that does nothing but part out Camaros and Firebirds.
The brackets need to be F body parts
Post  speedracing944 on Wed Apr 28, 2010 8:33 pm
I am also looking for the F-body bracket and accessories for my '93 Vette LT1.
Speedy:)
speedracing944
Post  kelleysj on Fri Apr 30, 2010 11:48 pm
So wait a sec you have to use a buick century alternator instead of the corvette alt are they the same or is there some reason for this? This is the first i have heard of this. Excuse my ignorance.
kelleysj
Post  Admin on Sat May 01, 2010 8:48 am
The V6 alt is smaller in dia. than the original one, and the room is need for clearance.
