Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
LS Series 3/4 Length Headers
Page 3 of 3 Previous  1, 2, 3
Re: LS Series 3/4 Length Headers
Post  gt1scca on Mon May 03, 2010 12:27 pm
Yes. Cool
I'll list them on the 944V8S website with pictures when the 1st set comes in.
It took a Buy-In of 5 sets minimum, but now they can be ordered anytime, any quantity.
Street & Performance ROCKS!
Thanks S&P, we needed these.
Post  gt1scca on Mon May 03, 2010 11:23 pm
I have spoken with the person @ S&P that fabricates headers, and verified with the owner of S&P, that the 944V8 Headers will be available for the LS engines up to the LS7 in 1 5/8" primaries and 2.5" or 3.0" collectors. This includes the LS3. All LS series engines that S&P has installed up to 550 HP perform admirably with 1 5/8" primaries in the 3/4 length header design.
Also, anyone that would like to specify 2.5" collectors for more clearance at the starter should let me know before the end of this week. Otherwise, all current orders will be built using 3" collectors.
Only the LS7 and LS9 require 1 3/4" primaries. 1 3/4" primaries on the other applications kills low-end torque and off-idle throttle response. If a true long-tube header were to be used, 1 3/4" primaries may be necessary on modified LS2 / 3 / 6 engines. Using a relatively short tube and collector, paired with a short exhaust system and 3" secondary tubing equates to basically a long-tube header's flow characteristics.
Exhaust design has been heavily debated here, and I am not claiming the above to be my opinion, nor 100% correct. It is, however the suggested application of a highly experienced manufacturer of high performance parts who has "been there / done that".
1 3/4" primaries are absolutely available if requested, but there will be an additional charge involved. Even so, the 1 3/4" primary version will still remain LESS than an equivalent RH header. I have looked at the Renegade Hybrids headers again, and their website lists them as, [gasp] 1 1/2" primaries - for ALL LS series engines. Now that, my friends, is a little bit too small for an LS3 rated @ 430+ HP. And the worst part? $1100.
Thanks for investing in absolutely the best production 944 V8 Conversion Header currently available. It only took 15 years of neglect to get here...And it happened in what...6 months or less?
Bye Bye itty-bitty headers with a Godzilla-sized price tag...
Post  944-LT1 on Tue May 04, 2010 12:35 pm
RH's headers are only 1-1/2"!!! I never knew that! Have they thought about what happens with a cam and head work when designing those? Laughing
Post  gt1scca on Tue May 04, 2010 12:51 pm
A set is being measured to verify, but that's what their site says.
Un-be-lieeevee-a-bullll...
Razz
Post  944-LT1 on Tue May 04, 2010 3:06 pm
I cant believe people pay 1100+ for those if they're really only 1-1/2". Might as well be drinking straws. Laughing
Post  Dawgz83948 on Tue May 04, 2010 3:48 pm
1-1/2" is a truck header. What tard's.....
Post  Bluemach1 on Tue May 04, 2010 4:13 pm
Would S&P be able to provide a CARB certified product?
Bluemach1
RH Headers
Post  Max Energy on Tue May 04, 2010 6:32 pm
Gentlemen,
FYI regarding size and pricing.
I have a set of RH Headers that I purchased approximatley 6 months ago for an LS3 and they are 1 3/4" primaries with V-Band Collectors.
I actually wanted 1 7/8" but they indicated that they had 2 sizes available 1 1/2" and 1 3/4"
Price was as follows:
1 3/4" LS Headers $849.00
Ceramic Coat inside and out $200.00 adder
V-Band Clamps $200.00 adder
Max George
225 573-0664
Max Energy
Post  Dawgz83948 on Tue May 04, 2010 8:02 pm
Nice, still too expensive. My headers are CARB legal and cost me $275 for my LT1.
Post  gt1scca on Tue May 04, 2010 10:51 pm
Max Energy wrote:1 3/4" LS Headers $849.00
A total of $1249.
Higher than I had thought.
Nice to finally know about the primaries for sure, but S&P will pay ball for less.
And the quality should be much higher. I expect someone will offer an even better deal eventually...
If the RH headers are what meets the needs of their customers, so be it. I knew there was another option lurking somewhere, and I found it, for a minimum Buy-In.
How about the fact that the S&P headers, un-coated, 1 3/4" primaries if requested, 3" collectors, with standard collector flanges, could be offered for $200 less than the same base RH header? Also, the S&P equivalent of the RH "fully-optioned" 1 3/4" headers would still come in @ $200 less. I offered all options included, with a design suited to the LS engines being installed in the 944 / 951, but these may be configured based on individual needs after the Buy-In is complete.
The LT1 has several nice solutions for outstanding prices. If we could send S&P a set of modified long-tube LT1 headers, or even 3/4 length, they would gladly make those also, and they would protect the rights to them.
Unfortunately, S&P does not have CARB certification.
I tried, but no deal.
Sorry these weren't available earlier, Max.
Post  modenas on Tue May 04, 2010 11:56 pm
do they not make a 400 header? not expensive and not to cheap?
modenas
Post  Joe on Wed May 05, 2010 4:38 pm
Hello Greg
I haven't understand all the possible diameters; sorry but translate the technical english is not easy for me
I have a question: what are the header diameter for a LS6; I would like 450/480 cv
Can you send me the price and some pictures of one "model" finished, please by
jonathan Wink
Joe
Post  gt1scca on Thu May 06, 2010 9:54 am
The final versions are being produced currently. The first sets should be here in about 3 weeks, Joe.
I will post pictures then, with all available options and sizes.
Greg
Post  Joe on Thu May 06, 2010 2:45 pm
ok
you have MP Laughing Laughing
thanks joe Wink
Joe
Post  adam7e on Tue May 25, 2010 4:29 pm
Finally closing in on 3 weeks, thank god! I hope good news any day.. Smile
adam7e
Post  adam7e on Tue Jun 01, 2010 3:11 pm
Hrm.. scratch Not yet folks.
adam7e
Post  gt1scca on Tue Jun 01, 2010 6:57 pm
I spoke to S&P today...
Driver sides are complete, including coating. The passenger sides are being coated, and should be complete very, very soon.
Post  DrBoost on Mon Sep 23, 2013 5:40 pm
Sorry to resurrect an ancient thread, but did these ever come out? Where/how/can I order these?
DrBoost
Post  adam7e on Tue Sep 24, 2013 6:59 am
I have a set of them that I've never used for sale. You can PM me if you're interested, I have them posted in their own thread on the for sale section. V bands/flanges, ceramic coated, gaskets, all the hardware. Cool
adam7e
Post  visian2002 on Tue Oct 08, 2013 6:38 pm
Hi ! I'm new here with no post yet. I would buy a set if they will fit my 2001 5.7 Ls1 corvette engine
at this moment I do not know the dia. Emai; me at [You must be registered and logged in to see this link.] Include price pls. Thanks, Ray
visian2002
