» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
1984 Dodge Daytona Turbo Z
Post  cfgioja on Thu Mar 18, 2010 8:54 pm
So this is not a conversion. But My father-in-law got a 1984 daytona turbo z off of his buddy who has owned it since it was brand new.
The car has 56K on it and starts up half way descent. Trying to figure out why its burning rich, causing back fires and sputtering.
I figured its just because it has sat for soo long that it just needs the cob webs blown out.
Re: 1984 Dodge Daytona Turbo Z
Post  turboswede on Tue Jan 14, 2014 3:25 pm
Probably failed vacuum lines, a bad coolant temp sensor or a bad oxygen sensor. The Chrysler 2.2 and 2.5 turbos were notorious for vacuum line issues. I've had several over the years and they are pretty robust once the vacuum lines are sorted and the sensors are in good working order. Plan on changing the belts, hoses and headgasket on one that has been sitting a bit.
Check out the following sites:
and this site:
Both should help you get it sorted.
Good luck!
turboswede
turbo z
Post  kevin924kevin on Wed Jan 15, 2014 11:27 am
Hello i had one of these cars. Check the computer under the passanger seat. these cars where bad for rusting under that area and the computer gets wet and plays games. I removed mine and wrapped it in plastic to keep it dry.
Post  zeusrotty on Wed Jan 15, 2014 4:20 pm
I had an 89 Daytona Shelby Turbo Z
With the enhancements it would beat anything out there. But it would pop a head gasket on a monthly basis.
zeusrotty
Post  Tim on Thu Jan 30, 2014 4:32 pm
There was a Shelby Daytona sitting in a field by my house in Texas for the longest time. I went to look at it twice and both times I lifted the hood a copperhead was sitting right on the shock tower. After that second time I never went back and it was eventually taken somewhere.
Tim
Tim
http://www.OEMPartHaus.com
