bushing on rear suspension arm
hey,
I was looking at the rear suspension and wondering if there is a part already out there and/or if it is worth changing. I'm not sure of the correct name of the arm or the bushing, but I circled it in the picture below. Since the arm doesn't purely rotate around that point isn't a ball joint the best way to go there?
Thanks for tolerating the boring question and any help!
Luke
Luke
Luke714- Posts : 441
Re: bushing on rear suspension arm
Rear trailing arm.
Dawgz83948- Posts : 603
thanks for the the right name.
That bushing is a very critical point, and there is some flex REQUIRED in it. For track use is it a weak point? Just seems like the sort of thing people may have developed a ball joint for, obviously it would increase the harshness of the ride (but who cares?, I mean, really?)
You can get delrin bushing from lindsey racing for that spot. I don't think they make a huge difference tho...unless it's on a race car.
awesome! thanks
i replaced all the bushings front and rear suspension on two of my 944's . they are track only cars an SCCA ITS 944 and SPEC 944 . they will drop your lap times . i will also do them on my 944 v8 time attack car over the winter brake . i would check the price before you get them from lindsey i got the ones i have from pelican parts at a better price .
962porsche- Posts : 135
Today at 9:56 am by ndog52
