» Oil Pan question
Today at 7:39 am by Hotrodz of Dallas
» 83' Porsche 944 LM7 Build
Yesterday at 1:39 pm by Jchard944
» Throttle body question
Yesterday at 12:02 pm by Rothaus
» Posche 924 Audi 4.2 V8 ABZ
Yesterday at 11:25 am by Ralphhh
Yesterday at 10:04 am by kevin924kevin
Sun Feb 18, 2018 8:05 pm by 948
» Magnuson supercharged car?
» WTB: LS powered 968
Radiator / Expansion Tank / Hoses
Post  Bluemach1 on Mon Mar 15, 2010 10:23 pm
I am trying to sort out what I need for using the 951 radiator.
1) Do I need to swap the 951 expansion tank with an N/A?
2) What hoses do I use? Can I use the GM F-Body or ????
I am seriously looking at this Radiator: [You must be registered and logged in to see this link.]
and running the stock dual fans. What do you think?
Thanks for your thoughts on this.
Bluemach1
Re: Radiator / Expansion Tank / Hoses
Post  Porch on Mon Mar 15, 2010 10:44 pm
If you've already got a 951 radiator, i'd say to stick with that until an upgrade becomes necessary. Mine's been working fine for 10k miles now...
Post  Bluemach1 on Mon Mar 15, 2010 10:56 pm
That was my original plan but the one that is in there just started leaking along a seam.
The one from Wizard is expensive but it is two row and all aluminum. Should do a nice job.... Not sold yet but thinking about it...
Still need guidance on hoses and the expansion tank. Any throughts?
Last edited by Bluemach1 on Mon Mar 15, 2010 11:03 pm; edited 1 time in total (Reason for editing : comments)
Bluemach1
Post  Porch on Tue Mar 16, 2010 10:03 am
I don't remember on the hoses, but it's been discussed...
As for reservoir, i sold my Turbo one (they're worth more) and bought an N/A one in better condition, and still came out ahead Smile
Expansion tank
Post  fliermike45 on Tue Mar 16, 2010 1:09 pm
I see in a LS1 cooling schematic that one of the heater lines is plumbed though a T that is at the base of the expansion tank. Is this a regular T or does it have some fancy valving inside?
Post  Porch on Tue Mar 16, 2010 1:59 pm
Mine is just a regular brass T, not sure how everyone else did theirs. It's really just a steam vent for the motor and the radiator. Once all the air is purged from the system it doesn't do a whole lot.
Post  87-944S on Fri Mar 19, 2010 8:55 pm
Do you have a NA car or Turbo? If you have an NA, get the lower radiator support from a turbo, makes for a factory look, worked perfectly for me, all the plactic bits bolted back up. There's been lots of discussions on multi-row versus single-row radiators. The LS engines seem to work just fine with the turbo radiator, which is single row. I'm using a Griffin all aluminum turbo replacement, not cheap, but about what a new stock turbo radiator costs, with the benefit of being all aluminum. Lots of cheaper options out there, with a little modification to make them fit.
Post  HandofTron on Fri Mar 19, 2010 9:45 pm
What are the differences between the n/a and turbo rad?
HandofTron
Post  87-944S on Sun Mar 21, 2010 8:22 am
The turbo radiatior is thicker, almost twice as thick and a little taller. The NA lower radiator bracket is flat, the turbo is U shaped, to accommodate for the difference in height.
