» ecotec swap
Yesterday at 7:02 pm by sharkey
» What is VSS?
Yesterday at 10:53 am by C4924S
» The famous Hydroboost issues....
Yesterday at 10:43 am by Hotrodz of Dallas
» RHD Conversion Issues...
Sun Apr 22, 2018 4:24 pm by UK952
» Considering doing LS1 Swap
Sat Apr 21, 2018 10:29 pm by hooplajr5
» WTB: 944 Turbo Roller
Sat Apr 21, 2018 8:31 am by Maxx
» Blue Alternator Wire
Fri Apr 20, 2018 11:22 pm by Porsche951toLS3
Thu Apr 19, 2018 4:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Thu Apr 19, 2018 6:16 am by bikerdude
Thu Apr 19, 2018 2:33 am by Flashy2003
April 2018
30
Affordable Rear Coil Overs?
Post  Bluemach1 on Tue Mar 02, 2010 10:59 pm
I am thinking ahead for my project and have been looking at rear coil overs. Prices seem to be pretty wide spread. I like the Bilstein escort cup. Expensive but set up with the correct offset.
What are good, affordable options that are being run on hybrids here?
With the coil overs, I plan on removing the torsion bars. Any thought on that as well?
Bluemach1
Re: Affordable Rear Coil Overs?
Post  Arthropraxis on Wed Mar 03, 2010 5:35 pm
There is a ton of info on coilovers and removing the torsion bars on Rennlist. I read about that and didn't see any negative comments. Seemed like popular among the racers.
Post  Bluemach1 on Wed Mar 03, 2010 6:03 pm
For sure on that! That is why I am opting to remove the torsion bars.
I can see the rubber bushings on the plates are torn and need to be replaced. Since I will need to beef up the rear end anyway for the torque of the V8 and might as well go all the way with the coil overs. I have seen just about every coil over under the sun discussed over there and it seems like there are as menay opinions as there are brands. That is why I thought I would see what the hybriders here are using / recommending.
Bluemach1
Post  Arthropraxis on Wed Mar 03, 2010 6:34 pm
You might as well do the trailing arm bushings while you are back there. I looked a a ground control set that had a decent price point and came with camber plates for the front coil overs.
