Trying to find times
+6
stu wright
Michael B.
gamman
10 posters
I have been talking to a friend about acceleration times and top speeds that these cars can produce once finished. I know each car will be different depending on rubber size, what shape the gears are in, and how the person can drive without destroying the car.
I did see some links before about the potential but I can't seem to locate them now. Can anyone help me. I need some evidence and something hard to show him so I dont sound like a D*** spouting off numbers out of a brochure.
Re: Trying to find times
I'm not sure if your going to find any real hard core 0-60 times, I don't think many will thrash their tranny that hard. I have herd some in the neighborhood of 0-60 in the 4to 5 second times. Top speeds have been reported in the 190 to 195 area. No proof. Even been said that there was a 205 once.
With the right gears, gobs of HP and a long enough road, anything would be possible.
times
My car, LT1 and street tires, no lsd was a 13.x, was over 100mph. Driver said spinning in 1,2,3.
Change your freaking avtar.
gamman- Posts : 112
When you say "these cars", are you referring to LS swapped cars? If so:
0-60 = about 8 seconds, if you're lucky and can get traction. Or would you prefer a hypothetical "you're never going to get this, but..." number? Because we could just say 4 seconds if it would make you feel better.
Top speed = ? I've read that it's around 173 for a stock turbo car. That's gear-limited, of course. On an N/A or S2 trans you'd be closer to 150mph. Most v8's won't rev as high as the turbo motor, but then again some of us have done the n/a 5th gear swap so that would add about 10mph or so. So figure with a turbo trans, an n/a 5th gear, a motor that can rev to about 6500, and taller-than-stock tires, you might be lucky to hit 185 or 190 downhill with a tailwind.
My car runs low 11's, traction limited, on DOT race rubber. Tire spin in 3rd. I have a video around here somewhere...
0-60 from a G-tech is 4.1, again traction limited.
Top speed GPS was 181 (N/A 5th gear) but the officer ticketed me for 200.
Michael B.- Posts : 83
i ran min at a local 1/8 mile strip to atune of 6.88 at 113 mph. my car gets great traction being an automatic trans .off the line is a feathering act on the accelerator.2nd gear shift dont happen till i hit 60 if i got my foot to the floor.that was with my first motor.im in process of buildin a new motor now that will have quite a bit more power.ive broke a couple of cv axles so ive learned to be easy on my takeoff.ive found a heavy duty cv axle replacement that they use in sandrails if i break another one.
stu wright- Posts : 312
never had it dynoed so i dont know for sure horsepower .im gonna guesstamate around 500 .that was with a 100 shot of nos.had dot slicks on it also.
i think ive had this disscusion before and we figured final drive ratio for the na automatic was about 3.89 ratio
cars
I just talked (2 weeks ago) to the guy at Raxles (nice guy). He said the guys were all wanting the 25 or 27 splines from the 968 as they are stronger.
Then he talked about moving the fuse....If the axles now don't break, what is "going to give"? I would sooner replace the axles every 2 years (like TonyG or other racers) than any parts in the tranny....however, I hope the axles last longer than 2 yrs....
gamman- Posts : 112
Axles?
You guys still dealing with axle issues?
I got these from GKN years ago. They are the perfect solution:
They take on my 600HP pretty easily & without effort.
The US spec 944 is 3.45 (11:38) ROW 3.08 (12:37)
1st 2.7143
2nd 1.500
3rd 1.000
rev 2.428
converter ratio 2.50
stall speed US 2800+-200
v8carreragts- Posts : 332
thanks 4 correcting me i knew it was somthing like that i was going by what xshop was factoring in for touqe converter ratio 3.45 is correct.i know its fairly low geared by my takeoff and low top end but itl get to 130 pretty quick
how much did those axles run you? I just downloaded their PDF catalog, but doesn't have prices. It also looks like they're based in Europe, I'll send them an email.
Luke714- Posts : 441
Oh they are a pricey bit. I became their supplier and I think I paid North of $480 each, wholesale. I will be surprised if they respond, as many have tried. I put some quotes together for a few blokes but none of them ever panned out. GKN told me they had maybe two left and they did not feel the need to make anymore if I could not get them sold. That had to be two years ago, I have not sold any since.
Everyone on rennlist says the GKN's are no longer available....
well then, I guess I'm at square one. Although, someone made the point that you'd rather have the axles shear than some part in the tranny. I guess I'll just see how things go with the stock units as long as I use a solid mount and that tranny brace.
Thanks for the help,
Luke
Luke
So, is there anything else out there that will measure up now?Michael B. wrote:I got these from GKN years ago.
Solid transaxle mounts and reinforcement braces / plates seem to be the latest "preventative" measures, but a bulletproof axle would be so much easier...
And definitely not as harsh on a street car.
gt1scca- Posts : 795
So you think that having more rugged axles is the equivalent of the solid tranny mount and brace? Who cares about street harshness, paaaaaa
Aren't they dealing with two separate issues for potential breakage?
Drivetrain flex in the case of the solid mount and reinforcement plate and twist/shear for the axles? (Not sure on the common failure mode for the axles.)
Fix one issue, fix 'em all. Fix it now or break it later.
One mans opinion.
So the question still remains, how to "fix" the axles. Wasn't it mentioned earlier that the Diablo replica guy built his own?
One mans opinion.
MN944S- Posts : 32
I don't have any real world experience dealing with this problem, I'm just trying to remedy it before I build it in the first place. What it sound like to me (not 100% sure on this) is that the transaxle would rotate enough with the stock mount that it would bottom out the spine on one of the axles, or somehow cause damage that way. It seemed fairly rare that the axle would actually fail in torsion from the shear stress (although that is the weak point of steel, to fail in shear). The solid mount and brace would help eliminate this. The only thing I've heard as far as the Diablo guy is concerned is the development, fabrication, and use of the reinforcement plate for the tranny case itself. This is a totally separate issue.
sounds like the topic changed i shouldnt have mentioned ive broke an axle lol.california motor sports has some axles that would probaly work on 944
