993 TT Brembo Brakes with rear 951 Brembo
Front brakes are 993 Turbo rotors and 4 piston Brembo calipers. The rears are 951 rotors and 4 piston Brembo calipers. Both front rotors measure 322mm x 31mm. Both rear rotors measure 299mm x 24mm. Adapters, hubs, and rotor hats are included to accommodate '87-'95 944/951/968 Porsches. The rear pads are almost new, however, the front pads should be replaced. Overall good condition with some minor cosmetic blemishes on the calipers. The front passenger caliper has some clear coat peeling, as noted in the picture below. The rotors are in good shape with only minor surface rust. They should clean up when braking a few times after installation.
Front 993TT Rotors
Driver's 993TT Rotor
Passenger's 993TT Rotor
Rear 951 Rotors
Driver's 951 Rotor
Passenger's 951 Rotor
Caliper Set
Driver's 933TT Caliper
Passenger's 933TT Caliper
Driver's Rear Brembo
Passenger's Rear Brembo
Front 993TT Rotors
Rear 951 Rotors
Driver's 951 Rotor
Caliper Set
ghostcloak- Posts : 83
993 brakes
How much are you asking for the complete brake set up?
Email me.
Max 225 573-0774
Email me.
Max 225 573-0774
Max Energy- Posts : 34
Re: 993 TT Brembo Brakes with rear 951 Brembo
^Email sent.
still available?
gamman- Posts : 112
Still available...
» Brembo Front Brakes, From my 968
» For Sale: 944 turbo M030/928S4 “medium black” Brembo front brake calipers
