» Headers, headers, HEADERS!
» Electric brakes
QT Bellhousing
QT Bellhousing
Post  ffmedic on Wed Jun 17, 2009 9:39 am
Go to my gallery I downloaded pics their with the QT BH, with a narrative as well.
Hey eric greg is their someway have more then one album on this site, I couldnt figure how to do it or it's just that each person is only allowed one album?
ffmedic
Re: QT Bellhousing
Post  gt1scca on Wed Jun 17, 2009 9:48 am
ffmedic wrote:Hey eric greg is their someway have more then one album on this site, I couldnt figure how to do it or it's just that each person is only allowed one album?
I attempted to add an album through the Admin panel...no luck. Also, I haven't found a theme @ Forumotion.com that offers additional albums. The phpbb.com themes are the only close alternatives, but they charge $6-up / month to host the forum...
I'm looking at .css scripts now...if I find something I'll let ya know.
The QT BH-Is the depth right?
Post  gt1scca on Fri Jul 17, 2009 11:45 am
ffmedic,
Did you verify the depth when you installed your QTI BH?
jhelgesen?
Is everything cool w/ the RM-6033?
It seemed to have been forgotten along the way, and I was curious as to why.
QuickTime Inc.
2397 Jewell Ave
Oskaloosa, IA 52577
Ross McCombs
Phone:641-673-4468
Fax: 641-673-4661
Email: [You must be registered and logged in to see this link.]
Re: QT Bellhousing
Post  ffmedic on Fri Jul 17, 2009 1:55 pm
gt1scca wrote:ffmedic,
jhelgesen?
QuickTime Inc.
2397 Jewell Ave
Oskaloosa, IA 52577
Ross McCombs
Phone:641-673-4468
Fax: 641-673-4661
Ok I am confused is this post from Ross at QT or ?, as far as the RM-6033 (what is that), I did finally get it in the car without the flywheel and with the backing plate that comes with the QT BH and so far from what I can see it all seems to fit very nicely right into the bearing that goes into the back of the crankshaft on the engine (whatever that bearing is called Razz). Hard to get pics of it because it pretty damn tight in their, but I will try .
Been sidetracked on the project my ranger blew the transmission, and I went ahead and pulled the engine while I was at it to replace the oil pump and timing chain (120k figured might as well do it now)
ffmedic
Re: QT Bellhousing
Post  gt1scca on Fri Jul 17, 2009 10:07 pm
Oh sorry...
And, thanks Dave.
I posted The QuickTime info in case we needed any further contact with Ross. jhelgesen has his car up for sale, so I was also asking him about his BH. Just following up a little, that's all. John's car is running (?)...
I think Tetzuoe has the QT also...
Bueller, Bueller...
Re: QT Bellhousing
Post  ffmedic on Sat Jul 18, 2009 1:10 pm
Still haven't answered my question though what's the RM-6033? Razz
Also just a fyi as well looks like with the backplate for the QT BH being added (it's like 2/8 of an inch something like that) it pushes the engine up that much as well when I put the engine in with it , you can tell things are abit tight with the motor mounts as well which should be an easy fix either leave it and it will go in ,
or because of the engine mounts I got you had to drill the original motor mount holes abit bigger ( forget the size) just basically enlarge the holes the motor mounts go into the cross member towards the front ( if you get what I mean by doing that) which is what I will be doing as well.
ffmedic
Re: QT Bellhousing
Post  944-LT1 on Sat Jul 18, 2009 2:11 pm
The RM-6033 or QTI-RM-6033 is the part number of the bellhousing made by quicktime bellhousings that mates any chevy engine to the the porsche 944 torque tubes.
Re: QT Bellhousing
Post  Tetzuoe on Sat Jul 18, 2009 5:51 pm
Ive got the qt housing on the ls. No idea if its in right but aside from my hoist being too short its it went in without drama
Tetzuoe
Re: QT Bellhousing
Post  ffmedic on Mon Jul 20, 2009 8:14 am
Give me some time, abit busy with the ranger, as soon as I get a chance will give some more details and hopefully some more pics if I can.
ffmedic
Kinda new here, but??
Post  RUF944V8 on Mon Aug 03, 2009 5:11 pm
Just wondering if the "alignment" issue with the pins you had to fill and relocate was addressed. If so, fixin to order mine...
RUF944V8
Re: QT Bellhousing
Post  Admin on Mon Aug 03, 2009 8:06 pm
I believe all is good, Someone else that I sent that direction has called and spoken directly to Ross, He said it was good and had sold 20 or so to BFR....
Re: QT Bellhousing
Post  ffmedic on Wed Aug 05, 2009 7:55 am
RUF944V8 wrote:Just wondering if the "alignment" issue with the pins you had to fill and relocate was addressed. If so, fixin to order mine...
Yep all is good , I just posted what I had and did , the holes should be drilled right now on the new BH.
I was working with ross on the hole issues is why I posted the pics and such because he was also looking for the same answers as you all have and wanted to put out a good product.
And let me reiterate working with Ross ( owner of QT ) was a breath of fresh air and a pleasure, Now their is an owner and a company that gives a crap about it's product and it's customer's.
Again thanks too Ross and QT.
Dave
ffmedic
Depth
Post  xschop on Wed Aug 05, 2009 8:04 am
What is the block to inner face depth, and the block to outer face depth?
Re: QT Bellhousing
Post  ffmedic on Wed Aug 05, 2009 8:09 am
xschop wrote:What is the block to inner face depth, and the block to outer face depth?
Will get inner in abit, the overall depth outside is 6 3/8 add 2/8 for the plate between the engine and the bh if your going to use that.
Anyone know what the max min depth you need on the Driveshaft tip into the bearing?(on the rear of the engine)
ffmedic
Re: QT Bellhousing
Post  kelleysj on Sat Mar 27, 2010 1:12 am
Im curious what you guys think is the C5 bellhousing better to install or the QT RM-6033 a better fit? is one better than the other? is it preference? some feedback would be great
kelleysj
Re: QT Bellhousing
Post  xschop on Sat Mar 27, 2010 9:25 am
Hey Kelly, Welcome to the club. No one has posted response to my Aug 5th post about that critical measurement which comes into question on clutch engagement/disengagement issues that some other people with the QT BH ran into. That is not too critical, except you will have to re-pull the engine and do the proper shimming process. What is CRITICAL is Shaft Concentricity. The last thing I heard was the QT BH was clocked wrong when sent out. Makes me wonder.
What I do know for a fact is the C5 Bellhousing is lightweight, strong ( I believe GM used the new alloy flow process on it) and I Mic'd a total of 4ea of the Manual 2-piece BH and 2 of the 1-piece Auto BH's. All critical dim's were within 0.0015" of each other. I've measured other BH's from other projects and none of them had such close tolerances, I was impressed.
That fact, and it being lightweight and the Manual BH has a nifty clutch-inspection cover had me sold. So I machined an adapter plate that mounts the C5 slave right to it that mimicked the C5 Clutch system. When used with Stock Camaro/C5 Clutch components, no shimming required.
Re: QT Bellhousing
Post  kelleysj on Sat Mar 27, 2010 12:17 pm
thanks xschop for the info i think i will go with the c5 bellhousing with the adapter plate.
kelleysj
Re: QT Bellhousing
Post  jhelgesen on Fri Aug 27, 2010 5:52 pm
QT housing is in my car. Motor mounted. Updates to follow.
jhelgesen
http://www.stahlwerks.com
Re: QT Bellhousing
Post  Admin on Fri Aug 27, 2010 8:49 pm
I have 2 cars in the shop at this very moment , both have QT bell housing and everything fits fine . No alignment issues or clutch problems.
Re: QT Bellhousing
