starter question
starter question
i have aquired a c5 manual 2 piece bellhousing that im using on my early small block conversion .i have a 153 tooth 10.5 flywheel that im using.can i use a factory style early small block starter with the c5 bellhousing.i know msd makes one that will work but they are rather pricey and i have a rebuilt gm starter that i would like to use for the early small block
stu wright- Posts : 312
Re: starter question
The factory GM starter should fit inside the 2-piece C5 bellhousing, from what I have measured.
Only starter issues have been with the 1-piece BH, and the MSD starter works with those.
gt1scca wrote:For the 12554980 (2-piece) BH, starter design and location is not an issue.
gt1scca- Posts : 795
thank you for your help im getting closer every day ill be ready for my adapter next week .waiting to get my block back from machine shop or id have tried my starter to see how it fit
Starter question
I have an LS3 with a 2 pcs. C5 bellhousing and the MSD starter would not work. I since have picked up a PowerMaster XS starter. I will install this week.
Max
Max
Max Energy- Posts : 34
im running an early sbc ill find out once my block gets back from machine shop im pretty sure my gm starter will work thank you for your input friend
what year block do you have? i got a 67 i am using with the c5 and the stock starter does fine.
modenas- Posts : 285
