» LS6 Batwing Oil Pan
» LS3 Exhaust
» JP's LS1 Conversion
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
January 2018
TOB or not TOB ?
TOB or not TOB ?
Post  brazuca on Tue Feb 02, 2010 7:08 pm
Im helping my son ,Oso ,on his conversion and I have a question about the hydraulic TOB : Can I use the regular TOB / ARM / SLAVE set up ? We are using the QT BH and a LT engine. Thanks for all the help we are receiving from this forum , we wouldn't be able to do it without. We have the bh in place an looks like we have room for the slave and fork.
brazuca
Re: TOB or not TOB ?
Post  Wild Bill on Tue Feb 02, 2010 11:02 pm
I'm considering doing the same thing. I have welded up and filled my transaxle mount with polyurethane and everything is positioned. Started the mounts tonight and will have them finished tomorrow morning. Looks like enough room however I'm not sure how long the fork is. I was planning to take a closer look once I finish my mounts and I am also almost finished my headers so I want to make sure everything is clear in the exhaust department as well.
Wild Bill
Post  gt1scca on Tue Feb 02, 2010 11:28 pm
The Quick Time BH will accept any GM throwout bearing setup. The GM bearing retainer bolt pattern is drilled and tapped on the QTI already. To use the late C5 Hydraulic Slave setup, 2(two) 1/4"-20 holes must be drilled and threaded on a 100mm bolt circle on the BH rear mounting flange.
Also incorporated is the cutout for the early GM clutch fork you mentioned. Post some pics of your setup when completed, so we can all be assured that QTI has corrected all problems with the RM-6033, including overall depth. Torque Tube mounting flange has been another problem area.
Suspect
Post  brazuca on Thu Feb 04, 2010 6:51 pm
Thanks guys. I'll probably end up going with the fork since it's easier maintenance. Which fork and slave cylinder will fit in the QT?
brazuca
Post  Wild Bill on Fri Feb 05, 2010 5:08 pm
Actually the hydraulic TOB is the slick setup and once you consider the price of the throwout bearing, fork and slave the $140.00 for the Hyd. TOB is pretty slick! I don't really see a maintenance issue? HTOB has one more O-ring. Slave would be mounted above my exhaust collector and subject to more heat than the HTOB.
Wild Bill
Post  brazuca on Fri Feb 05, 2010 7:57 pm
OK .Will be ordering the hydraulic tob and the other clutch components this weekend. Thanks.
brazuca
