» Transaxle rebuild
» Tpc LS adapter plate
Cooling System
Cooling System
Post  Jim968 on Mon Feb 01, 2010 1:08 pm
I found this link on the Griffin Radiator website. It is a good article on cooling systems and the second half is specifically on LS Cooling Systems including: great flow diagrams, pictures, descriptions; LS cooling system plumbing variations for conversions (like heater delete), single row vs dual, does dual-pass cool better?, how steam vents work, etc. Lots of good stuff worth the read.
Jim968
Re: Cooling System
Post  944-LT1 on Mon Feb 01, 2010 1:49 pm
Nice article!
Re: Cooling System
Post  xschop on Mon Feb 01, 2010 1:59 pm
The heater ports (if used) are hooked up backwards in those diagrams...
Re: Cooling System
Post  944-LT1 on Mon Feb 01, 2010 2:54 pm
The heater ports (if used) are hooked up backwards in those diagrams....
Yup. The bigger 3/4" is return from heater and the smaller 5/8" is the supply. So thats weird. Also, they have the hoses (post heater core) going to an expansion tank which is also weird. Surprised they didnt mention a recirculatory valve like the H-valves we use.
Cooling System
Post  fliermike45 on Mon Feb 01, 2010 3:57 pm
Excellent article, thanks for linking to it.
?'s
Post  gamman on Tue Feb 02, 2010 11:53 am
a bit off topic, where would I find the parts to put the system in my car back to the "stock" conversion way? I have an extra few hoses where the windsheild resevoir goes to help increase the volume of fluid by the PO. I want to just put them back.
I have ordered a manual, but its on its way, I won't get it for a few weeks....
Thanks.
gamman
Re: Cooling System
Post  944v8inDFW on Tue Feb 02, 2010 4:20 pm
If you can post up some pictures of current plumbing that would really help everyone give you a good path to clean things up.
944v8inDFW
Re: Cooling System
Post  944-LT1 on Tue Feb 02, 2010 4:56 pm
Yeah. I have no idea what you mean. Pictars......
Re: Cooling System
Post  gamman on Wed Feb 03, 2010 9:56 am
deleted to my own thread, sorry.
gamman
Excellent article, will definitely put this one to good use.
Post  Guest on Sun May 02, 2010 12:22 pm
Thanks for all the help.
Guest
Guest
Re: Cooling System
