944Hybrids
Welcome to our forum.
Stock GM Cam Specs
Page 1 of 1 • Share •
Stock GM Cam Specs
I'm trying to figure out what cam I have the part number is GMPT BC 17 600. I was told by the guy who sold me the motor that it was a lt4 hotcam but i don't think it is
. I've called Comp cams and summit with out any luck. Could someone on here look at there old stock cam and get the numbers off it?
msmoorenburg- Posts: 75
Re: Stock GM Cam Specs
I'm still looking to se if that part number comes up, but I'm striking out. Here is a list of LTx cam specs though for the moment.
Cam----INT / EXT
Stock LT1---202@ .450/ 207 @ .450 (1.5RR)--- 117 LSA
Stock LT4--- 203@ .476/ 210@ .480 (1.6RR)--- 115 LSA
GM Performance Parts
LT4 Hot Cam --- 218@ .525/ 228@ .525 (1.6RR)--- 112 LSA --- 1800-5800 RPM
GM12370847 --- 234@ .539/ 242@ .558 (1.5RR)--- 112 LSA --- 2000-6800
GM12730846 --- 220@ .509/ 230@ .528 (1.5RR)--- 112 LSA --- 1800-5800
Comp Cams
CCA-07-304 --- 210@ .500/ 220@ .510 (1.5RR)--- 114 LSA --- 1000-5000 RPM
CCA-07-305 --- 220@ .510/ 230@ .510 (1.5RR)--- 114 LSA --- 1500-5500
CCA-07-306 --- 230@ .510/ 244@ .540 (1.5RR)--- 112 LSA --- 1800-5800
CCA-07-500 --- 206@ .480/ 212@ .488 (1.5RR)--- 112 LSA --- 1000-5000
CCA-07-501 --- 212@ .488/ 218@ .495 (1.5RR)--- 112 LSA --- 1200-5200
CCA-07-502 --- 218@ .495/ 224@ .503 (1.5RR)--- 112 LSA --- 1500-5500
CCA-07-503 --- 224@ .503/ 230@ .510 (1.5RR)--- 112 LSA --- 1800-5800
CCA-07-464 --- 202@ .550/ 212@ .546 (1.5RR)--- 113 LSA --- 1000-5000
CCA-07-465 --- 210@ .560/ 218@ .550 (1.5RR)--- 113 LSA --- 1200-5200
CCA-07-466 --- 218@ .570/ 224@ .565 (1.5RR)--- 113 LSA --- 1800-5800
CCA-07-467 --- 230@ .576/ 236@ .570 (1.5RR)--- 113 LSA --- 2000-6000
CCA-07-468 --- 242@ .584/ 248@ .579 (1.5RR)--- 113 LSA --- 2200-6200
Crane Cams
CRN-104227 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000 RPM
CRN-104228 --- 210@ .479/ 224@ .518 (1.5RR)--- 112 LSA --- 2000-6000
CRN-104241 --- 218@ .498/ 218@ .498 (1.5RR)--- 116 LSA --- 2800-6500
CRN-1449555 --- 210@ .531/ 218@ .531 (1.5RR)--- 114 LSA --- 1900-5600
CRN-1449571 --- 210@ .531/ 218@ .531 (1.5RR)--- 112 LSA --- 1000-5800
CRN-1449561 --- 216@ .551/ 224@ .551 (1.5RR)--- 115 LSA --- 1500-6000
CRN-1449581 --- 220@ .551/ 220@ .551 (1.5RR)--- 112 LSA --- 3000-6500
CRN-1449591 --- 224@ .551/ 224@ .551 (1.5RR)--- 114 LSA --- 3000-6500
CRN-1449601 --- 228@ .600/ 232@ .600 (1.5RR)--- 112 LSA --- 3500-6500
Edelbrock
EDL-2108 --- 218@ .525/ 218@ .525 (1.5RR)--- 112 LSA --- 1500-5500 RPM
Lunati
LUN-54778LUN --- 206@ .469/ 215@ .489 (1.5RR)--- 112 LSA --- 1200-4500 RPM
Accel
ACC-74220 --- 215@ .499/ 220@ .510 (1.5RR)--- 114 LSA --- 1200-5800 RPM
ACC-74211 --- 211@ .499/ 219@ .525 (1.5RR)--- 112 LSA --- 1000-5800
ACC-74219 --- 219@ .525/ 219@ .525 (1.5RR)--- 112 LSA --- 1200-6200
Cam----INT / EXT
Comp Cams
Crane Cams
Edelbrock
Lunati
Accel
golfduke- Posts: 62
Anychance you could put some approximate HP next to the cams you mentioned just curious. I installed the comp cam with the 480 x 488 dimension.
The CCA-07-500 one
The CCA-07-500 one
ffmedic- Posts: 102
I'm working on it... They're a good deal subjective though just because the power/tq ranges vary a lot more than the overall hp difference.
I'll do my best though, from what I can gather.
golfduke- Posts: 62
Ok this is what I put in my engine:
I am also going with 1.6 rockers so this should put me 512/520? is my guess?
Thats kinda the area I am looking for close to the hotcam but not quite which I think should give me good hp,reliablity and gas miledge as well. Which is what I am looking for.
I am going with trickflow heads (new design just comming out 54cc not the 62cc) the heads have 2.02 intake 1.60 exhaust.
I am using a holley 52mm throttle body with a plate behind it.
I am using tight tuck headers with 3inche exhaust.
I am also porting out the intake to match the gaskets as well.
I am guessing this should put me around 400hp at the flywheel ( I hope )
I will also once it's running have it dyno tuned.
Am I right about the hp numbers or am I off ?, am I headed in the right direction is what I am trying to find out.
Thanks ahead of time.
Dave
Dave
ffmedic- Posts: 102
Similar topics» looking for a mini stock for rent
» ShopNBC, Sans Host Jim Skelton, Floats Stock Offering
» C9VE-B
» stock suspension alignment specs
» stock width on fox body
» C9VE-B
» HELP . . . Electrical gremlin
» Rich's LS powered 944 track car
» First Time Swap 85 Porsche 944 to LS6
» Oil and steering cooler options
» selling conversion parts due to new baby
» Strut brace?
» What LS Exhaust Manifolds / Headers
» building a 1983 948 on a budget - pointers?
» To " badge or not to badge "
