» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Tie Rod End Question.
Post  Admin on Thu Jan 28, 2010 7:55 pm
Does anyone know what the taper is for the tie rod to spindle taper?
Spindle tech
Post  xschop on Fri Jan 29, 2010 5:43 am
Check out the end dimensions and pull out the calculator
http://i94.photobucket.com/albums/l96/xschop/944S2.jpg
Re: Tie Rod End Question.
Post  Admin on Fri Jan 29, 2010 7:46 am
I'm to lazy, What is the angle?, is it 7 degrees or is it some thing different?
Post  xschop on Fri Jan 29, 2010 8:07 am
It is either 7 or 10 degrees. I've seen 7 & 10 degree taper reamers, but never knew if manufacturers calculated off one or both sides of the taper bore to get that angle. I have a 5/8" reamer on hand and that is what I used to re-ream the spindle for the bump-steer bolt which is way stronger than the stock dimension.
Post  Admin on Fri Jan 29, 2010 8:24 am
Strange
Post  xschop on Fri Jan 29, 2010 8:39 am
According to the taper per foot rule, I get 1" taper per every foot on the Porsche Tie-rod using those spindle dimensions.
