» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
New Wide Body kit.
Page 3 of 3 Previous  1, 2, 3
Re: New Wide Body kit.
Post  Arthropraxis on Sun Jan 31, 2010 2:26 pm
You may want to make a modular hood header combo. So the hood or header panel will work independent or complement each other. The Corvette has the rise extending in to the header so you could no use that piece alone. The Camaro has a flat panel with the air intake slit so you could use it with a stock hood. Might create a larger audience.
Post  bluehellfire666 on Thu Feb 04, 2010 11:32 pm
so do you think you could fit a 325 under the front fenders with the right offset? I'm thinking of going with a 15X10 on all four corners with some nice thick meat on the bones all the way around...maybe dial in some more 50-50 traction?
bluehellfire666
Post  Admin on Sat Feb 06, 2010 9:41 pm
There is 6" between the back of the tire and the inner fender well. You can fit just about anything in there
Post  bluehellfire666 on Sun Feb 07, 2010 5:43 pm
niiiiiice!!! do you have any pics like that of the front? I've been under the front of the car a LOT, so i can visualize it pretty well if i have a reference point
bluehellfire666
Post  Admin on Sun Feb 07, 2010 8:16 pm
By the end of this week I should have good picture of everything. Of course, I'm in the middle of changing the design. I can't leave well enough alone.........You will like it! Cool
Post  bluehellfire666 on Sun Feb 07, 2010 10:23 pm
I'm SOOO EXCITED!!!!
i'll check back multiple times a day until you post up you're new designs!
bluehellfire666
Post  bluehellfire666 on Sun Feb 14, 2010 2:49 pm
any updates?
bounce bounce bounce bounce
bluehellfire666
UPDATE!
Post  Admin on Fri Feb 26, 2010 3:58 pm
Here is the final shape in rough primer!
Post  skywalker01 on Fri Feb 26, 2010 6:03 pm
Very nice!! Excellent work!!!
skywalker01
Post  bluehellfire666 on Sat Feb 27, 2010 12:58 am
AAAAWWWWEEEESSSSOOOOMMMMEEEE!!!!
so i'm guessing that this won't work with the turbo rear splitter? Not a problem by me...just wondering what i could do to stabilize the rear end a little bit....maybe i'll have to make one myself!
Looks really good (in case you didn't get that already...haha) so what did you change...you said you could never leave well enough alone.
Regardless i will be in for a set this summer once you're in production!
Keep up the kick ass work man...you're really one-upping us all here!
Ethan
bluehellfire666
Post  Admin on Sat Feb 27, 2010 8:09 am
I added bulges on top of all the wheel openings. It's hard to tell what it really looks like in the garage on the lift, I plan to have it out side this weekend and I can take better pictures.
Thanks for the compliments. I's a lot of hard work!
Post  xschop on Sat Feb 27, 2010 8:22 am
Classic. That Looks like a whole different kind of beast that Porsche didn't have the vision to see thru. Which it is. What will you wind up doing to the inner fender (original) lips?
Post  Admin on Sat Feb 27, 2010 8:29 am
On the front I think I will bond in just enough of a lip to be able to screw the original well liner to it..
On the rear it'll have some fiberglass extension.
Post  944-LT1 on Sat Feb 27, 2010 9:37 am
I dont think it gets any better than this. Im not sure if it was done intentionally or by devine mistake but it has the 80's 911 turbo lines which is what I immediately thought when I saw the pics above. Oozes sexy. Great job Eric!
......make a version for those with 2" wider quarters already?!?! Very Happy
Post  944-LT1 on Sat Feb 27, 2010 9:41 am
..............If you do, ill test your crossmember on an LS3 for free! Laughing
Post  Admin on Sat Feb 27, 2010 9:44 am
For those with 2" quarter already, These will fit......Just get the saw zal and remove all necessarily sheet metal and quick easy fit! Laughing Laughing Laughing Laughing Laughing
Post  ykalinin on Wed Mar 10, 2010 12:00 am
Those look great What a Face
ykalinin
Post  xschop on Wed Mar 10, 2010 9:34 am
Hey Eric, Which polymer do you use to stick fiberglass panels to the body. I have a few tubes of Loctite 2-part PLASTIC Epoxy that I want to do the finall glue job to your NICE bumper cover. Also how is the front nose panel removed from the NA car since I will be building my custom air intake next week? I see the 5 screws on top but can't tell how it is attached anywhere else....Thanks, Rob
Post  Dawgz83948 on Wed Mar 10, 2010 9:57 am
There should be 4 screws on top (pop the headlights) 4 8mm nuts under the lights and 2 10mm sheet metal screws into the fenders (also under the lights) There you go X....
Post  Admin on Wed Mar 10, 2010 7:58 pm
Rob, I haven't gotten to the point of finding the right adhesive just yet. I thought I might just copy Skywalker!
Here are some pictures of the car outside finally! Shocked Very Happy
Post  xschop on Wed Mar 10, 2010 8:02 pm
Fekkin Demented Twisted Evil
Post  Porch on Wed Mar 10, 2010 8:12 pm
That IS wide! Looks great Smile
Post  cfgioja on Wed Mar 10, 2010 8:38 pm
Wow. what offset are you running those tires are spread out.
Looks good, that should handle good.
Update?
Post  Jazzek on Thu Jul 04, 2013 4:51 pm
Admin wrote:Once the real parts are done I will make an instructional write up in how to install and it'll be on my web site. The front fenders are going to be complete fenders. After looking at what Skywalker has gone through to get his on I just can't see myself making people have to do that much work just to install a wide fender. Plus the extra cost of the adhesive and extra body work. You will have to bond on the rear . Not much of a way around that. I hope to have everything really slick so there will not be to much prep needed for paint either.....
I know I'm late to the party, but did this ever become a kit? Looking at wide body options, I would definitely be interested in this one compared to some others.
Jazzek
