» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
c5 slave setup
c5 slave setup
Post  modenas on Thu Jan 21, 2010 12:48 pm
what does everyone slave look like?
modenas
Re: c5 slave setup
Post  msmoorenburg on Thu Jan 21, 2010 1:04 pm
you have to take the end off and use the Russell Performance #640281 and the Aeroquip FBPA0030-26 (Page 24 in the Manual)
msmoorenburg
Re: c5 slave setup
Post  modenas on Thu Jan 21, 2010 1:12 pm
is your slave fitting far or close to the bellhousing. like mine it far
modenas
M O D E N A S
Post  xschop on Thu Jan 21, 2010 1:17 pm
Hey MO, do you have ADD? LOL... I've told you that if you've already installed the factory C5 TO bearing with the quick disconnect line, then you have to remove the BH to get that aftermarket Russell adapter to -4AN to fit because of that set pin.
where there's a will
Post  xschop on Thu Jan 21, 2010 1:33 pm
EDIT..... BUY the Mcleod fitting!
Re: c5 slave setup
Post  msmoorenburg on Thu Jan 21, 2010 1:34 pm
look close you can see the russell adapter installed
msmoorenburg
Re: c5 slave setup
