944-LT1 LS3 Conversion - Page 4 EmptyYesterday at 2:55 pm by Porsche951toLS3
» Intake Piping For Very Tight Clearances?
944-LT1 LS3 Conversion - Page 4 EmptyYesterday at 2:46 pm by MotoRider42HC
» WTB: LS Swapped 944
944-LT1 LS3 Conversion - Page 4 EmptyYesterday at 1:16 pm by porschekid7
» tips on removing headers?
944-LT1 LS3 Conversion - Page 4 EmptySun Jun 23, 2019 8:57 pm by Worryless
» Lighten clutch pedal feel?
944-LT1 LS3 Conversion - Page 4 EmptySun Jun 23, 2019 8:44 pm by Worryless
» Torque Tube Heat - What is Normal?
944-LT1 LS3 Conversion - Page 4 EmptyWed Jun 19, 2019 12:14 pm by superman22x
» FOR SALE: Kokeln Dual Master Bracket
944-LT1 LS3 Conversion - Page 4 EmptyWed Jun 19, 2019 12:13 pm by MotoRider42HC
» Replacement Radiator
944-LT1 LS3 Conversion - Page 4 EmptyWed Jun 19, 2019 11:20 am by Hotrodz of Dallas
» ISO ls swap done with working AC :)
944-LT1 LS3 Conversion - Page 4 EmptyWed Jun 19, 2019 8:19 am by stilov
» 1987 Porsche 944 S - Transaxle FOR SALE
944-LT1 LS3 Conversion - Page 4 EmptyFri Jun 14, 2019 7:04 pm by MotoRider42HC
June 2019
3456789
10111213141516
17181920212223
24252627282930
Page 4 of 4 Previous  1, 2, 3, 4
944-LT1 LS3 Conversion - Page 4 Empty Re: 944-LT1 LS3 Conversion
Post  944-LT1 on Thu Aug 26, 2010 5:39 pm
just curious, on the manual brake setup. How much of a difference does using the wilwood master have on the performance of the brakes compared to just running a stock master?
Im not sure. Havent run the car yet to see. But, to guess, I would assume I would not feel any difference. Theres just not enough difference between the two MC's to really get a solid "wow" from my foot. Laughing Im running 993TT w/CD rotors and coolers up front and 944 turbos in the rear and with the stock MC, it was pretty good. We'll see!
944-LT1 LS3 Conversion - Page 4 Empty FIRST START!
Post  944-LT1 on Sat Oct 02, 2010 2:54 pm
Heres my first start. I cant believe how easy modifying the LS3 wiring harnesses is! Everything works great.
Had the computer tuned by Steve at TunedbyFrost.com. I have to say....He's the best/fastest out there!
Post  944-LT1 on Sat Oct 02, 2010 2:57 pm
Still to do...
Plumb in radiator, expansion tank and lines.
Finish headers and build exhaust system.
....well, I think thats it! Very Happy
Post  skywalker01 on Sat Oct 02, 2010 5:44 pm
Looks and sounds great man! I'm hunting a wascawwy ewectwikal gwemwin associated with the
parking lights. Darned German wiring!!
skywalker01
skywalker01
Post  cfgioja on Sat Oct 02, 2010 6:33 pm
thought it would be cool to run it with flames shooting out the side. It looks great though. I wont have mine that clean when I am done. I am just trying to get the engine in there and get it running for now.
944-LT1 LS3 Conversion - Page 4 Empty trouble shooting an electrical short circuit
Post  944convert on Sun Oct 03, 2010 7:53 am
If you have a short circuit that keeps popping a fuse, find someway to replace the blown fuse with a spare 12v bulb.
The bulb will light up whenever power is applied until the short is located and removed.
It will save a lot of fuses and should keep you from melting any wiring.
Post  skywalker01 on Sun Oct 03, 2010 8:07 am
Damn dude! You are just a plethora of information; a compendium of commentary - thanks! Why didn't I think of that!
skywalker01
skywalker01
Post  remington7 on Thu Mar 24, 2011 5:39 pm
Any updates on the LS3 conversion?
remington7
944-LT1 LS3 Conversion - Page 4 Empty LS3
Post  kevin924kevin on Thu Mar 24, 2011 6:29 pm
Hello 944LT1,The car looks GREAT. hows it coming? Just a little late info, i am going to put the LS3 in my 924. From everything i have read including the install manwell, the motor is stand alone if you bought the e-rod kit. This kit comes complete,( legal in all 50 states ) it should be 9 wire hook up. You remove your gas pedal and install a few screws to mount the new one. It tells you where the peddle must be located to function properly. The e-rod motor comes stock at 430hp, according to GM these motors are actually 10% stronger, so another 43hp. I am going with the LS3 and the stage two cam, from factory.( two years warranty) It starts at 480hp, so 10% more means 528hp at the motor.Add headers and a good tuning and you are around 550 plus. I have a freind with chevy 2 (nova) he has this motor in his car. After a few tweaks and nice pipes it dynoed at 557hp STOCK. One scary car,did i mention STOCK. Now in my case, car weighs 2650lb, not sure about the nova. These motors are power houses. In my opinion, you really dont need any more STOCK HP. What does you car weight? I look forward to seeing more photos of you car.
Last edited by kevin924kevin on Thu Mar 24, 2011 6:32 pm; edited 1 time in total (Reason for editing : mist a point)
Post  944-LT1 on Thu Mar 24, 2011 8:06 pm
Everything is done. I made my own long tube headers......which is a difficult job to say the least. Laughing
I will post some pictures a bit later.
Post  remington7 on Fri Mar 25, 2011 5:57 am
Have you had it dynoed yet? Very Happy
remington7
Post  Techno Duck on Fri Mar 25, 2011 7:45 pm
Sweet!.. what clutch did you end up choosing?
Also did you stick with the electronic throttle body? I think if i went with an LS3 i would personally go with a cable driven, was never a fan of the drive by wire on my friends M3, but maybe its gotten better.
Ive been talking to a buddy of mine getting ready to swap in an L92 and ive been thinking about these LS3 crate engines. I was looking at the hot cam version available which gives an extra 50bhp for like $300 extra. I was thinking 'man, that is a no brainer.. 480bhp/475ft-lbs'. But then it got me thinking if that was too much power.... i think 300whp with my stock 2.5L is fast enough, i cant even imagine ~400whp! All i can think about is having some serious traction issues!
Post  944-LT1 on Sat Mar 26, 2011 5:56 am
remington7 wrote:Have you had it dynoed yet?
No, not yet.
Techno Duck wrote:Sweet!.. what clutch did you end up choosing?
Also did you stick with the electronic throttle body? I think if i went with an LS3 i would personally go with a cable driven, was never a fan of the drive by wire on my friends M3, but maybe its gotten better.....i think 300whp with my stock 2.5L is fast enough, i cant even imagine ~400whp! All i can think about is having some serious traction issues!
Im using the LS7 clutch. Im also using the DBW pedal as well. It was too easy to hook up not to use it. I had the computer tuned by frost and with the midlength headers, he estimated 380-390 rwhp. I decided against the midlength headers and built longtube headers with 30" primaries and 3" by 3" collectors. I also am building a straight intake, running a Meziere electric water pump and am only running an alternator. So I think im going to be at the 400 rwhp range conservatively. I was thinking of a cam but will hold off to see if the car/me can handle it.
Right now Im working on the fuel system and interior. Cameras always need batteries and I never have any. Laughing
Post  Arthropraxis on Sat Mar 26, 2011 11:53 am
How did you get the proper spline with the LS7 clutch disc?
Post  944-LT1 on Sat Mar 26, 2011 6:31 pm
I took a Porsche disc to my clutch shop. They removed the rivets and clutch lining and replaced it with a Luk lining. I was going to use a disc like from the mopar one but the guy at the clutch shop said he could do it.
Post  Arthropraxis on Sat Mar 26, 2011 6:44 pm
Good to know. How much did that cost?
Post  944-LT1 on Sat Mar 26, 2011 8:41 pm
I think I paid him something around 180? Not sure because he also balanced my flywheel.
Post  944-LT1 on Wed Sep 23, 2015 4:20 pm
Weighed my car yesterday.
Post  948 on Wed Sep 23, 2015 5:25 pm
944-LT1 wrote:Weighed my car yesterday.
So, am I to assume this beast is on the road, finally?
Vids and pics please? Cool
Post  944-LT1 on Thu Sep 24, 2015 8:23 pm
Well.....The wildwood MC developed a leak that's directly above the header and I'm scared of fire (remember expuppy?).
Anyway, hopefully in short time I can have it replaced and get a video!
Post  948 on Fri Sep 25, 2015 7:12 am
I do recall the fire.... affraid
Post  944LS4 on Thu May 05, 2016 12:49 pm
No guts no glory, never mind fires. Where's the update?
944LS4
944LS4
