Tubular cross member
+25
subterfuge
IFeelOld
samsdad
joeytoad83
porschyn
v8944
Wild Bill
mmacias2
Bluemach1
gamman
ghostcloak
Vorsche944
stu wright
ykalinin
MN944S
29 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: Tubular cross member
Just got my cross member from Eric. Very nice.
Bare in mind this is a non A/C unit but, I'm sure he'll do a great job on that model as well.
Regards
Mark
Regards
Mark
samsdad- Posts : 8
Admin, please PM me a price (if you have that set) for the LT rack. In what circumstances would I need the bump steer kit?
Thank you, PM received. I will probably be in touch in the next month or so.
..... and my pm is where?
Dawgz83948- Posts : 603
That price is reasonable. What is the lead time? Can't do it right now but maybe summer.
I have seen some mention of AC vs non AC unit (I will want the ability to have AC)- what is the difference for the LT1 cross member?
Think it'll fit/work for a RHD (right hand drive) Turbo S as well ? i.e. in terms of steering wheel to rack coupling clearance...
Korenwolf- Posts : 17
Admin- is that bump steer kit going to be adaptable to the manual steering tie rods?
There is no differences for the LT1 as far as the ac or no ac setup,
Right hand drive I have no Idea! I don't have a car around here to test fit it on.
I have not test fit it on a manual rack yet. All I can say is that if it has the same tie rod end as the power rack of an 87' NA or Turbo it'll fit. Or send me a used tie rod end and I'll custom make it to fit.
The manual rack tie rod ends are male threads instead of female- I can send you mine if you want, my car won't be going anywhere for a while once it gets into the garage. I'll be ordering an xmember before the end of the month.
Manual tie rod assy-
Power tie rod assy-
pics by paragon products.
Power tie rod assy-
Crossmember for ls1 with AC
Please, PM me the cost of the crossmember for LM7 with AC.
H.K.
H.K.
porschyn- Posts : 9
With the new headers in, I was curious how things were going with the cross member? Does it look like they may work together?
adam7e- Posts : 63
Bringing this one back from the dead.
Does anyone know if this is still available? Does it work with LSx motors in the 951?
brinskan- Posts : 15
Tubular Crossmember
Admin,
any word on a crossmember for LS1 conversions. i think i want to go this route seems easier and with fewer parts. looking to purchase, if available, this fall when i start on my conversion again. don't know how nor have enough posts to Pm so how do we communicate.
Punisher948- Posts : 39
Page 4 of 4
Today at 12:47 am by sharkey
