Tubular cross member
+25
subterfuge
IFeelOld
samsdad
joeytoad83
porschyn
v8944
Wild Bill
mmacias2
Bluemach1
gamman
ghostcloak
Vorsche944
stu wright
ykalinin
MN944S
29 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: Tubular cross member
Will we be able to use our existing motor mounts or will new ones have to be fabbed/purchased?
ghostcloak- Posts : 83
I am setting this up to use just standard short GM mounts, same as we have been using, and the stock "unmodified " oil pan.
Just a thought, but it would be pretty easy to switch to a different rack all together...which would mean no "special" headers as well!
Is there anything from Flaming River that would work? Stock Corvette, or...?
That was another reason for doing this. It would be real easy to fit any of the Mustang II type racks in here. I just need some dimensions on where the steering shaft goes up and I think it would be very easy to do.
Eww.. Mustang parts...
LOL just kiddin
LOL just kiddin
New cross member parts are in!
I just got the new parts for the final Cross
member design. Should have it finished today.....
Man, that is some thick stuff! You could probably get away with some thinner stuff, don't you think?
it's all 1\4 " at the moment. I have considered 3\16, but I have to think of the end user first. I want it to stay together. Also, before you say it, as of this afternoon the weight was just the same as the factory cross member with the uprights bolted to it.
Very, very interesting. I am really interested to hear what comes out of the rack options you are looking into. Specifically if will allow use of unmodified headers. That would make my california conversion a bit easier.
Yes, sir. quite a few actually. There are a few shorties that might work. I think a few have been proposed in the thread headers, header, HEADERS on the board.
Also, as a minimum, to be able to use teh stock header with out modification would be a help. maybe still have to mod the steering shaft??
My Pacesetters are legal (CARB EO#). Not sure about LS, as long as they have a CARB EO they are legal.
Dawgz83948- Posts : 603
That looks great. Fixes a lot of the issues with the conversion. It is too bad I have already orderred the other conversion pieces that will be obsolete with this crossmember.
PM me with how much.
Until I do, why can't I improve it.
I don't have a price at the moment, I have to put together everything/cost that will need to come with it to work properly. I should have the price figured out by Tuesday.
When I sell these, it will come with motor mounts, all new bolts, and a custom made adjustable bump steer kit.
Final Crossmember
This is the final cross member! It is only for the LTx motor setup at the moment
It will come with a custom Bump Steer kit and Rubber motor mounts. I will have comfermation that this will fit the LSx motors in 2 weeks. As stated before you can use an unmodified stock oil pan. Yes you can by just the Bump steer kit also. At the moment I only know that it fits an NA car. I will check it on the Turbo in 2 weeks.
Page 2 of 4
Today at 12:47 am by sharkey
