Current Thinking On Car With No Heater -- Hose Routing
+5
Johnny Johnny
944v8inDFW
9 posters
What is the current thinking on a car with no heater, as far as heater hose routing goes?
Loop back the hoses?
Cap the Hose barbs? ( i think that would require no T stat)
Thoughts? Suggestions?
944v8inDFW- Posts : 147
Re: Current Thinking On Car With No Heater -- Hose Routing
Personally i would run a loop, unless you can find a GOOD way to cap the outlets.
Looping would be easier on you and the pump. Or use them to run a another fenderwell radiator etc.
Has anyone ever come up with a molded U bend in 3/4 heater hose?
I know theyre out there. Cant remeber what car I saw it on. Coulda been a PCV hose though.
Anyway, 5/8" 180 degree silicone hose is popular in the "air-induction" marketplace.
Theyre on ebay and rice stores.
My heater/AC delete project (and dash, and gauge cluster, and ...)
Johnny Johnny- Posts : 164
Will this do it?
crpcontitech 2001-2001 vw golf
"2001-2001 VW Golf GTI Turbo Cooling/Coolant Hose Cylinder Head Hose Flange
VW Golf cooling/coolant hose manufactured by CRP-Contitech for 2001-2001 VW Golf GTI Turbo VW Golf"
Autohaus AZ
3341 East Corona, Phoenix, AZ 85040
Phoenix Area & International Order Hot Line - (602) 276-9402
Outside the Phoenix Area Order Hot Line - (800) 240-4620
Fax (602) 276-6716
(*I am not affiliated, BTW...)
Autohaus AZ
Fax (602) 276-6716
gt1scca- Posts : 795
For almost all of my hoses, i just went to the parts store and politely asked to look through their hoses...
Porch wrote:For almost all of my hoses, i just went to the parts store and politely asked to look through their hoses...
^ I did the same ^. They will have a section with elbows, 180s and straights in that size
I used my heater loop to add a supplemental radiator (don't need the heater much in FL). I can't figure out how to put a picture in this thread so I put them in my gallery - Jim968. You can also just loop it with some SSteel flex hose. I posted a picture of that method also. I got the flex heater hose from Summit.
Jim
New guy on the site...Very impressed. Great job Admin!
1994 968/LS1
Jim
1994 968/LS1
Jim968- Posts : 5
cap or loop
Studying the Pump routing, capping the ports individually would be like running the heater valve closed causing a greater velocity to the radiator. That's why I will run without a T-stat and the inner heater port hole closed off for better cooling. This will just take a little longer for the engine to warm up to full temp.
If you just cross the ports over, less velocity of the coolant to the radiator will result because the coolant will just be recirculating in the engine....my $0.02
The sad thing is I found the part # to the hose that fits that water pump perfectly. I don't rember it now, but if you go to an auto parts store, I went to O'reilly, you can flip through their hose catalog and there is a perfect 180 U hose that goes from the two different sizes.
The only thing you have to do when you get it is cut the ends to length. Thats it, no bending, no thinking. Just go check out the book at your autoparts store.
