Mon Jul 08, 2013 1:56 pm by Admin
L33 owners chime in please
I am reading as much as possible in preparation to do an LSx swap. I am leaning towards an L33 setup as some of your have done and am interested to hear if you are happy with it in terms of power and drivability. My car is a track-only 86 951 with a cage and Motons done last year. I don't need A/C or P/S. I would also like to maintain my suspension geometry which I understand is altered with the crossmember shimming/drop. Thanks
eclou- Posts : 102
my $0.02
I like the idea of the L33 for the extra power and weight savings, especially for a track only car. I have stripped out everything including the power steering. I opted to not "lower" the crossmember. Instead, I added a bump in the hood to accommodate the throttle body etc. Obviously, the intake needs to be changed to as LS1/6. I also considered running the intake reversed. However, the firewall and TB would intersect at the main pinch weld. It would also require some sort of airbox in the passenger compartment that would draw too many questions by the race officials (my opinion).
Power comments aside...I did spring for a Comp Cam, roller rockers, lifters, etc etc.
968gene- Posts : 259
Re: L33 owners chime in please
968gene wrote:I like the idea of the L33 for the extra power and weight savings, especially for a track only car. I have stripped out everything including the power steering. I opted to not "lower" the crossmember. Instead, I added a bump in the hood to accommodate the throttle body etc. Obviously, the intake needs to be changed to as LS1/6. I also considered running the intake reversed. However, the firewall and TB would intersect at the main pinch weld. It would also require some sort of airbox in the passenger compartment that would draw too many questions by the race officials (my opinion).
Is your car complete? Have you done a dyno? I would be interested in learning about the torque curve and what usable RPM range you are seeing. Would you also mind sharing your cam specs?
Gene
eclou- Posts : 102
Today at 9:30 am by Gutterboy
Yesterday at 4:12 am by Colibri Green
Tue Mar 26, 2024 1:29 pm by Blaizefed
Tue Mar 26, 2024 11:30 am by Raymond-P
Tue Mar 26, 2024 6:49 am by 948
Wed Mar 20, 2024 9:52 pm by Raymond-P
Wed Mar 20, 2024 11:17 am by Rob44
Tue Mar 12, 2024 1:22 pm by dcoutofstep
Tue Mar 12, 2024 12:10 pm by dcoutofstep
Tue Mar 12, 2024 10:12 am by ndog52
