Flywheel tooth question.
How many teeth are there on a GM 12571611 flywheel recommended for the LS swap?
Re: Flywheel tooth question.
168
» Flywheel offset 85.5 944
» ls2 automatic, what flywheel should I buy
» Clutch and Flywheel. What should I run?
