» Headers, headers, HEADERS!
» Electric brakes
Other Transaxles
Page 4 of 4 Previous  1, 2, 3, 4
Re: Other Transaxles
Post  xschop on Wed Jan 27, 2010 12:06 pm
Yes, I know for the r154's , but since I got a C5 diff with 2.73 R&P, I want to go with an newer AR5 or an older AX15 4x4 (for the tranfer case tail) and better suited ratios. What would be Ideal is to find TCS's for the AX15 since those boxes are so plentiful. I have a lead on a low mile one for 300 bucks Very Happy
Post  944-LT1 on Wed Jan 27, 2010 2:27 pm
The place to call and find out for sure is Rockland Standard Gear. Theyre huge on the Aisin transmissions. They may have a solution such as dual cone, carbon composite, steel, et cetera. But in my searches, I havent seen anything such as triple or dual.
Post  Porch on Tue Feb 09, 2010 9:34 am
Okay, this is gonna sound kinda dumb because i don't really know what is being referenced...but i saw someone on rennlist mention that the S2000's have a primary gear reduction. I assume this would be a step between the motor and the transmission that would have the same effect as a higher-ratio gear set. Feasible?
Post  Admin on Tue Feb 09, 2010 11:31 am
Usually a primary drive system is just a gear box that is installed between the trans and drive train/drive shaft. I have installed these in large trucks as a gear reduction, they are made to be an over drive set up as well. The problem would be is that I don't know how you would install it in our setup.
Post  xschop on Tue Feb 09, 2010 12:00 pm
Lot of trouble to complicate the set-up with a gear multiplier. I just got my C5 differential from UPS. As soon as the ice storm goes away I'm gonna do some preliminary measurements for a tranny hanger for it. In the process, I had a brain fart for a better 944 tranny mount that I will make for this summer's NA tranny rag-a-thon......I would like to get the dims on a solid 944 tranny mount so I can convert them to this type of set-up....
someone smell what's cookin? Twisted Evil
Post  Porch on Tue Feb 09, 2010 12:19 pm
I was imagining some kind of planetary that could go in the "bellhousing" area of the transaxle. Couldn't be that difficult, could it?
