» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
Replacement Fuel Pump
Post  Dawgz83948 on Thu Jan 07, 2010 1:44 pm
I just ordered a pump that is supposed to bolt into a 944 with no mods. The price is reasonable and it outflows the standard pump. [You must be registered and logged in to see this link.]
Re: Replacement Fuel Pump
Post  Porch on Thu Jan 07, 2010 2:08 pm
Wow, that's great!! I've been dreading the death of my fuel pump...but no more! Thanks!!
FORSCHE
Post  xschop on Thu Jan 07, 2010 3:25 pm
Very Happy
I really don't have to order anything from those snobs now...
EDIT: Big Thanks for the find Cool
Post  Dawgz83948 on Thu Jan 07, 2010 3:34 pm
xschop wrote:Very Happy
Have you delt with them before? What happened?
Post  xschop on Thu Jan 07, 2010 3:45 pm
I was talking about bypassing anything that rhymes with ORSCHE or ENNLIST....
Last time I dealt with a Porsche fuel pump back in the day, I got squeezed if you know what I mean...
I was hoping there to be an alternative and an upgrade at the same time for a decent price....looks good
Post  matthewb on Thu Jan 07, 2010 5:02 pm
I wonder how much that flow falls off after you go above 40 Psi. They claim their 225 LPH at 40. I am considering running right around 40 psi on my car when i put it back together.
matthewb
Post  Dawgz83948 on Thu Jan 07, 2010 5:05 pm
matthewb wrote:I wonder how much that flow falls off after you go above 40 Psi. They claim their 225 LPH at 40. I am considering running right around 40 psi on my car when i put it back together.
This is the flow numbers from the close to the same series of pumps.
Post  Dawgz83948 on Sun Jan 10, 2010 2:12 pm
It's a direct bolt in (case is slightly larger but still works with stock strap) and just as quiet as the stock 944 pump.
Post  erioshi on Sun Jun 22, 2014 4:57 am
The pump listed above looks quite a bit like an Autobest F4170 .. which also comes up as an "economy" OE replacement pump for the 1979 (and possibly other years) external high-pressure pump with a Rock Auto search.
Rock Auto lists it for about $59, and it is also available on Amazon for about the same price.
So why bring this back from the dead?  A bit of testing shows my 928 has a dead fuel pump causing the no-start issue.  I'm planning an LS swap in the future, but for now it would be nice to move the car in & out of the garage under it's own power.
Looks like Rock Auto lists it as an OE replacement for the '79 924 NA as well, but not the turbo. Hmm.
erioshi
