FLYWHEEL TORQUE SPECS ???
IS this correct? And do I put Blue or Red Loctite or NADA?
Engine Flywheel Bolts (First Pass) 15 lb ft
Engine Flywheel Bolts (Second Pass) 37 lb ft
Engine Flywheel Bolts (Final Pass) 74 lb ft
And what about this? 5.3L Ironblock with alloy Fidanza flywheel and LS1 Camaro stock Pressure plate is what I am sticking in tomorrow..... So do I torque to spec for the 5-speed or 6-speed? Loctite?
Clutch Pressure Plate Bolt (5-Speed) 15 lb ft + 45 degrees
Clutch Pressure Plate Bolt (6-Speed) 52 lb ft
PORH
PORH
Re: FLYWHEEL TORQUE SPECS ???
I would use Blue locktite.
Also, I've never torqued steel flywheels in steps like a head gasket. I do them in a star pattern like a wheel, and torque them to spec. Maybe snug them 1st to keep everything centered, then torque tight. If its aluminum, then the steps are probably a good thing.
Is it an aluminum flywheel or steel?
Whats the engine difference in a car with a 5 speed or 6 speed? If the 6 speed came with an LS1, and the 5 speed came with a v6 or something, then I would use the 6 speed spec... cause you have the ls1
Smell what I'm cookin?
m73m95- Posts : 77
flywheel
It's an alloy Fidanza Flywheel. Lightweight. I won the Camaro LS1 Pressure plate off ebay for 40 bucks its is NOS. The clutch plate is the CP4018 from Autozone 11". I am just going to torque it like you said, like a wheel pattern torque....Blue Loctite huh. Red's a Byatch to get out later and can gall alloy sometimes. I had to take everything out to do a repair to that rear passenger's side control arm mount area, the nut inside broke loose. I got somethin' for it.
Yeah, blue locktite. I don't use the red on anything, unless it specifically says to use it in the shop manual. That $#** is impossible to get off.
m73m95- Posts : 77
xschop wrote:IS this correct? And do I put Blue or Red Loctite or NADA?
PORH
those are the specs I used in my car, same flywheel as well but in 12". My pressure plate came with its own set of torque specs though, and they did not look like either one you listed. Yes, blue loctite on all bolts IMHO. It's enough to prevent backouts, but not enough that you will snap heads upon removal.
golfduke- Posts : 61
» Torque Specs for rotor hats
» VSS Setup (and tuning)...
» 944 Billet-Polyurethane Transmission Mounts....PM for Details
Today at 12:47 am by sharkey
