Need Help with a measurement!!!!
Can someone measure the opening in the firewall for the clutch master cylinder? My car is an hour away at the body shop and I'm having a part made to adapt the Tilton to the firewall and the machinist needs the diameter to 0.001"
Thanks in advance.
I'll share the results when I get the part in my hand.
Gene
Thanks in advance.
Gene
968gene- Posts : 259
Re: Need Help with a measurement!!!!
i mesured the opening on mine at 1 5/16 nches968gene wrote:Can someone measure the opening in the firewall for the clutch master cylinder? My car is an hour away at the body shop and I'm having a part made to adapt the Tilton to the firewall and the machinist needs the diameter to 0.001"
Thanks in advance.
Gene
stu wright- Posts : 312
35.00 mm (1.3779")
The 944 stock MC is 34mm at it's base
Making an adapter is almost moot because the Wilwood MC has to be milled at the bolt mounting points to match the 50mm C2C firewall studs.
