can i use the same trany with ls1 swap
+2
pantera8250
6 posters
i was wondering i have 89 porsche s2 can i keep the trany for the ls1 or i need ls1 trany
pantera8250- Posts : 5
Re: can i use the same trany with ls1 swap
pantera8250 wrote:i was wondering i have 89 porsche s2 can i keep the trany for the ls1 or i need ls1 trany
You must keep the 944 tranny, unless you plan on cutting/hammering out the tunnel. Preferably you get a turbo transaxle.
Dawgz83948- Posts : 603
i was trying to find averything i need to do for the swap. online but i only find motor mount crossmember and pilot bearing, anything else you think ill need
The Porsche 944 V8 Conversion Manual.
gt1scca- Posts : 795
pantera8250 wrote:i was trying to find averything i need to do for the swap. online but i only find motor mount crossmember and pilot bearing, anything else you think ill need
Uhh, bellhousing, clutch, pressure plate, flywheel, hydraulic throwout bearing, radiator, vacuum h for heater (late cars), radiator fan, headers, manual brake conversion plate (or power booster), etc.
am gona start buying averything piece by piece it shouldnt be hard to do the swap..
That may very well turn out to be the longest word in this thread...Dawgz83948 wrote:, etc.
backbrace lolgt1scca wrote:That may very well turn out to be the longest word in this thread...Dawgz83948 wrote:, etc.
stu wright- Posts : 312
the only thing i dont understand its the motor mounts i seen some texas performance for 145 can i use those.
Yes.
For any GM SBC / LT1 / LS V8 engine.
are those the only one i use. for the motor or i need to get additional ones
You will nee the motor mount uprights and a set of factory Gm motor mounts for the block. I can supply those with the uprights if you need. PM me. I am Texas Performance Concepts.
gt1scca wrote:The Porsche 944 V8 Conversion Manual.
I'll second that. Haven't ever done a conversion before so I have no right to give any other advice
Luke714- Posts : 441
