LT1 Oil pan
+3
kelleysj
ffmedic
Oso
7 posters
LT1 Oil pan
Hi, I've been looking through out these forums and some google searches online but I can't find a detailed diagram of all the measurements of a modified oil pan from a 95ish camaro. Is there another pan I'm supposed to buy then modify or can I use my original?
If there aren't any diagrams is there one that I can buy that's already good to go?
I'm trying to do this project within 2-3 months so time is factor.
Thanks guys.
Thanks guys.
Oso- Posts : 28
Re: LT1 Oil pan
Look in my gallery:
That oil pan I am using I have found to be the best to modify, because it seems you don't have to modify to much of it.
I'll try and get some measurements posted in the next couple of weeks.
And no I have not found a oil pan you can use because the LT1 uses a one piece rear main seal.
I used that pan after modifying a couple of different pans fyi (stock pan included) decided to go with the pan in my gallery because more clearance for the crank, not to difficult to modify ,and holds more oil.
hope this helps.
hope this helps.
ffmedic- Posts : 103
Does anyone sell LT1 oil pans?
Why doesnt anybody build these they make them for the LS1 conversion? If anybody makes a modified oil pan i will buy one hook us non-welding mofos up.
kelleysj- Posts : 194
Re: LT1 Oil pan
Greg (GT1SCCA) will make you one.... I just ordered one
Re: LT1 Oil pan
With a tubular cross member you don't need a modified oil pan!
When you factor in the cost of buying a custom oil pan, or buying an oil pan then spending the time to modify it, plus the cost of uprights, or the time to build them, the tubular crossmember makes a lot of sense.
