» NDog52's 1986 NA 5.3 Build - A Summary
Need some help with rear rotors EmptyYesterday at 11:30 am by Gutterboy
Need some help with rear rotors EmptyWed Mar 27, 2024 6:12 am by Colibri Green
Need some help with rear rotors EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
Need some help with rear rotors EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
Need some help with rear rotors EmptyTue Mar 26, 2024 8:49 am by 948
Need some help with rear rotors EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
Need some help with rear rotors EmptyWed Mar 20, 2024 1:17 pm by Rob44
Need some help with rear rotors EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
Need some help with rear rotors EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
Need some help with rear rotors EmptyTue Mar 12, 2024 12:12 pm by ndog52
Need some help with rear rotors Empty Need some help with rear rotors
Post  mjp427 Wed Dec 23, 2009 3:30 am
I went to go order rotors for my car but need some help. What is the difference between 86 and 87 turbo rear rotors. I have a 86 NA and am installing turbo calipers. I thought 86 turbo and 87 turbo rotors were the same. I am not sure if my turbo calipers are 86 or 87 or if it even makes a differernce. Any help is greatly appriciated!..
Matt
mjp427
Need some help with rear rotors Empty Re: Need some help with rear rotors
Post  turbobob924 Wed Dec 23, 2009 12:27 pm
I am pretty sure they are the same.
You just need to adjust the spacing to fit on the NA hubs in the rear. I can't remember where I bought it but it is a cheap kit.
turbobob924
turbobob924
http://www.turbo924.com
Post  matthewb Wed Jan 06, 2010 11:10 pm
You will need the 86 turbo rotors for your 86 arms. With the later offset came a deeper rotor hat. I put the turbo brakes on my 86 rear suspension and went through the same uncertainty but I now know the answer.
matthewb
