5.3L DoD or AFM
5.3L DoD or AFM
Has anybody considered the Active Fuel Management (AFM) formerly Displacement on Demand (DoD) engine that chevy put in the Trailblazers and Envoy's in 2005? From my understanding it's the same as the 5.3L truck motor but is capable of shutting off four cylinders in light load conditions. I am wanting to build my Porsche as a daily driver and the 5-7% MPG increase would be welcome.
The motors on car-parts.com are similarly priced to the 5.3L truck motors (L33) although there are fewer of them. I also browsed several trailblazer forums and heard they have similar reliability.
Any thoughts?
Any thoughts?
Ender751- Posts : 28
Re: 5.3L DoD or AFM
That would be pretty awesome but how is AFM controlled in those vehicles? If its all in the engine computer ECM, then it should be easily doable. But if it requires parameters from PCM/BCM, youre in for a long ride (no pun intended).
I know of no one who currently runs DOD or AFM in their conversions as of yet.
I looked at that as an option, briefly
They are all DBW and I just don't want to deal with anymore than I have to. If you want to cam it that will be a problem. I have seen on the truck forums where people have programmed it out and swapped parts to make them normal motors. So, if it is not what you thought you can make it non DOD.
Re: 5.3L DoD or AFM
I don't know anything about the DOD, but you might also look into Lean Cruise--available on the Holden computers, and also something that can be added to the GM computers (search around on the EFI Live forums).
Re: 5.3L DoD or AFM
944-LT1 wrote:That would be pretty awesome but how is AFM controlled in those vehicles? If its all in the engine computer ECM, then it should be easily doable. But if it requires parameters from PCM/BCM, youre in for a long ride (no pun intended).
I was worried about the same thing. I'll get onto a trailblazer/envoy forum and try to find out how that is controlled. I also wondered if i could simply over-ride everything and simply control how many cylinders are running with a switch on my dashboard, it would be inconvenient but worth it.
thanks
Porch wrote:I don't know anything about the DOD, but you might also look into Lean Cruise--available on the Holden computers, and also something that can be added to the GM computers (search around on the EFI Live forums).
I will look into that. Thanks
