» New 944 widebody & aero
Yesterday at 5:56 pm by scryfst
Yesterday at 11:23 am by Murrdog9000
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
Modified Hooker 2312 - SOLD
Post  Johnny Johnny on Fri Dec 11, 2009 12:10 pm
Modified Hooker driver's side header and regular passenger side, includes exhaust pipe connectors. This is a slight improvement to the original design, as it uses fewer new pieces, and the flange did not need to be ground down or modified. HOWEVER - this is a tight design and will ONLY fit motors that are not "dropped". If your motor is dropped, then there will be interference with the upper steering shaft collar.
Nice welds and fitment, flange mating surface is straight and flat. You'll probably want to paint/coat them.
Cost + shipping from Toronto.
Last edited by Johnny Johnny on Sat Dec 12, 2009 2:24 pm; edited 2 times in total (Reason for editing : removed references to price)
Johnny Johnny
Re: Modified Hooker 2312 - SOLD
Post  944-LT1 on Fri Dec 11, 2009 1:05 pm
Oh those are awesome welds. Shocked Did you MIG them?? I cant MIG like that. Mad
So since I spaced my crossmember 1/2", I cant use these???
Post  Johnny Johnny on Fri Dec 11, 2009 1:52 pm
These were TIGged, not be me since a) I don't have a TIG machine, and b) my welding skills are not adequate *yet*. I have a local machine shop that does all my welding for me, and did the pair I sent to xschop in the summer.
Like it says - these will fit when using the standard motor mounts (xschop, BFH, Renegade) with no crossmember drop. It *might* fit with a small drop, you *might* need to persuade them (by denting them), but you're on your own if you do that.
944-LT1 wrote:Oh those are awesome welds. Shocked Did you MIG them?? I cant MIG like that. Mad
Johnny Johnny
Post  Admin on Fri Dec 11, 2009 2:49 pm
You named off three different motor mount upright, Which on does it work with? BFR (who no longer makes them) and RH uprights both use cross member spacers. Xschop I'm unsure if they use them. My up rights are similar to BFR and require cross member spacing. Do you have Xschop's uprights in your?
Post  Johnny Johnny on Fri Dec 11, 2009 3:43 pm
I have my own, but they are the same dimensions as Rob's.
Just to clarify, the crossmember drop is so that the hood clears the motor. Technically, you don't need it, if you want to run a hood bulge. I have a nice fibreglass one if anyone's looking.
Johnny Johnny
Post  Admin on Fri Dec 11, 2009 5:45 pm
You need to get a set of up rights made from Greg's drawing. I would check your headers against that before you start selling them as a generic fit all. Rob's mounts are different than anyone else's
Post  gt1scca on Fri Dec 11, 2009 6:21 pm
Johnny Johnny wrote:I have my own...
There are many variations that will work, if the correct mounts and plates are used.
As far as the headers...
Looks like the #1 primary tube sits lower and further "out" than the first set...
Would possibly hit the strut tower (?)...
It was relocated why, JJ?
For your car?
Post  Bluemach1 on Fri Dec 11, 2009 8:22 pm
All you need to do now is get these CARB (california air resources board) certified and everyone is a winner!
Bluemach1
2312's
Post  xschop on Fri Dec 11, 2009 9:32 pm
If no-one else wants them. I'll take them. They will fit even with 3/4" drop, the motor may have to be moved to the passenger side a bit, but no biggie. When you get rid of the bulky cereal bowl and can place the back of the driver's head 3/8" away from firewall/plate they fit very nicely and clear a single and even The Tilton Dual MC nicely as well...
My version is tucked further away from the top shaft coupler and later I'm going to build a compact coupler shaft for my next swap...
Post  Johnny Johnny on Sat Dec 12, 2009 7:45 am
gt1scca wrote:As far as the headers...
For your car?
The #1 primary does site lower, but is also tucked in closer to the other primaries. Makes for a more compact unit, reduces the length slightly to get it closer to the other primaries, and also reduces the number of bends. This is basically the second iteration of the design I did over the summer. It's easier to fabricate, as it requires fewer cuts, grinds, and additional pieces to make.
I was going to use these myself, but I'm going a very different direction altogether for my exhaust system.
Johnny Johnny
Post  Johnny Johnny on Sat Dec 12, 2009 7:46 am
Bluemach1 wrote:All you need to do now is get these CARB (california air resources board) certified and everyone is a winner!
It's freezing with snow up here in Toronto - I wish I was IN California right now!!! Sad
Johnny Johnny
Post  Johnny Johnny on Sat Dec 12, 2009 2:21 pm
Sold to Chris.
Johnny Johnny
