March 2019
Clutch Master Upgrade
Page 2 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: Clutch Master Upgrade
Post  968ls1 on Mon Dec 21, 2009 11:57 am
Looks good!
968ls1
Post  xschop on Mon Dec 21, 2009 12:42 pm
1/8 NPT or 1/4 NPT....
some confusing sh*t. I thought these were different bores.... scratch
Post  968ls1 on Mon Dec 21, 2009 1:23 pm
Yea you will need an adapter from the master to the -4 hose. The part number is 555-100210 from Summit $4.49.
968ls1
Post  xschop on Mon Dec 21, 2009 1:36 pm
I ordered this one after talking to Greg. The pics between the two adapters are identical That's why I thought the bore diameters were different and NPT meant a standard thread. There should be a thread(no pun intended) started about all the different types of threadings. When you say 1/8 to me I take it the O.D. of the threads are 1/8"... The Wilwoods are bored like 3/8".... Everything should go metric and call it a day. lol!
clutch update
Post  turbobob924 on Mon Dec 21, 2009 3:50 pm
This may be wrong thread but it is related...
I found out my current setup (8.5 sintered iron racing clutch) was an good shape and only needed one part replaced so I'm not going to switch to a twin disk setup like I was think I had too.
While at quartermasters, I was talking to them about how much pedal effort was required to work the racing 8.5 setup. They said that going to a smaller diameter MC with more travel would fix the pedal effort issue. The clutch I have is designed for a 3/4 MC. So if the 94 stock is 7/8, that's why it takes so much effort!
I am not sure it the factory 944 clutch MC is 7/8 or 3/4???? Can any confirm which?
I see that wilwood has a compact one that you can get for like $50 and has a .70 diameter cylinder.
This is what I am going to try.
wilwood part no 260-6579
Merry Christmas to all!
turbobob924
turbobob924
http://www.turbo924.com
I call travel
Post  xschop on Mon Dec 21, 2009 4:05 pm
If there is enough travel in the 944 pedal for a smaller dia. MC, then great. But the problem is the 3/4" stock MC doesn't push the Standard Pressure Plate splines in long enough to get good disengagement and the grinding commences when the plunger in the stock MC wears. For a super stiff PPlate what you are doing is the right idea. Just hope you have enough pedal travel and find a master with long enough throw....
Merry Christmas to you and yours and a Happy Hybrid Year to come.....
Post  turbobob924 on Mon Dec 21, 2009 4:33 pm
merry xmas to you too and thanks for the feedback.
Yes I need to make sure there is enough travel but in my case, this clutch is like a button. It requires very little travel to engage it and I had to put an adjustable pedal stop in as it wa able to travel too far!
I believe the wilood MS has 1.4" of travel. S/B more than enough.
turbobob924
turbobob924
Mr Sloan
Post  xschop on Wed Dec 23, 2009 10:52 am
Do you have these dims handy? I won't be crawling in that damn crawl space for a while....
And are these Clutch pushrod and clevis the same for all years 944?
I found that the 7/8" Wilwood pushrod is NOT 113mm (end to flange) like the PDF file shows, but 104mm TOTAL LENGTH END TO END. I have decided to make a custom clevis and reuse the Wilwood pushrod because the compression head is a unique design and stronger than a 7mm hemisphere, plus it incorporates a catch . I'll just make a longer clevis and tap it 5/16-24 and keep the willwood pushrod catch that the 944 pushrod doesn't incorporate, and call this mod DUNDEE.
Post  gt1scca on Wed Dec 23, 2009 11:22 am
xschop wrote:And are these Clutch pushrod and clevis the same for all years 944?
I found that the 7/8" Wilwood pushrod is NOT 113mm (end to flange) like the PDF file shows, but 104mm TOTAL LENGTH END TO END...
Son of a...
Total PR (stock 944) length = 112 MM
Clevis length = 40 MM
Clevis "pin" (on pedal) = 10 MM DIA.
xschop wrote:I'll just make a longer clevis and tap it 5/16-24 and keep the willwood pushrod catch that the 944 pushrod doesn't incorporate...
Make me (1) while you're at it.
1 more dim
Post  xschop on Wed Dec 23, 2009 12:06 pm
minor detail but critical....
what is the clevis "pin" center to threaded end or back end?
Heck, I need all 4 dims
Santa will get one out to you......Merry Christmas
Post  gt1scca on Wed Dec 23, 2009 12:12 pm
(#1) Clevis length = 40 MM
(#2) Clevis thickness = 10 MM
(#3) Clevis width = 16 MM
(#4) Clevis "pin" center to threaded end = 32 MM
944 PR thread length = ~28 MM
Thread depth in Clevis = 22 MM
Anything else, santa ?
"Hoooo. Hoooo. Hoooo..."
Post  xschop on Wed Dec 23, 2009 12:46 pm
Not having to crawl up under there at 20* outside temp is a great present to me thanks bro. santa
Post  Arthropraxis on Wed Dec 23, 2009 1:00 pm
Is there any use for the Pcar slave rod? It looks longer than the master cylinder rod.
Inquiring minds WTK
Post  xschop on Wed Dec 23, 2009 1:05 pm
7/8" Wilwood MC stroke = 36mm
3/4" 944 MC stroke = 36mm
What LUCK!.....santa
Post  xschop on Wed Dec 23, 2009 1:20 pm
[/quote]Is there any use for the Pcar slave rod?[/quote]
Paperweight
Post  gt1scca on Wed Dec 23, 2009 8:25 pm
968ls1 wrote:Yea you will need an adapter from the master to the -4 hose. The part number is 555-100210 from Summit $4.49.
Part numbers must have changed...
From SummitRacing.com:
-3 AN Male to 1/8 in. NPT Male Fitting
Earl's Performance 982203ERL
90 Degree, -4 AN Male to 1/8 in. NPT Male Fitting
Aeroquip FBM2031
Post  turbobob924 on Tue Dec 29, 2009 4:24 pm
THis is great stuff!
Very nice pictures and dims too!
Im interested in more information on the "custom clevis".
Is it made of brass?
Was it totally made form a solid block or something that you "tweaked" to make work?
My new MC is on the way from summit!
turbobob924
turbobob924
Post  gt1scca on Tue Dec 29, 2009 7:15 pm
turbobob924 wrote:...the "custom clevis".
Is it made of brass? Was it totally made form a solid block or something that you "tweaked" to make work?
Solid billet, machined to spec. Pushrod length difference added to clevis, watch for the part pic coming this week.
7/8" Wilwood MC...
Already got mine, Bob.
UPS dropped it off today.
Post  turbobob924 on Wed Dec 30, 2009 9:47 am
Thanks!
You are the documentation king!
turbobob924
turbobob924
Post  xschop on Fri Jan 01, 2010 1:19 pm
4130 steel is a better material for the Wilwood pushrod to 944 Clevis adapter. It is stronger than the steel piece that Porsche made. Any Al+ Alloy material will wear out quickly at the (10mm dia.) 944 Clutch pushrod pin and the sidewall strength around the 5/16-24 Wilwood pushrod could be a problem if using alloy as well....You will run into Galvanic corrosion problems
here's the bolt-on solution...
Post  Porch on Mon Jan 04, 2010 11:51 am
gt1scca wrote:The full spec...
(Edit in progress...)
This should be squeaky-close, without actually mocking it up on the firewall, and without
using the firewall plate. Add the thickness of the plate if reinforcing the firewall...
Test-fit may prove a slight length adjustment, but the adjustability of ~30MM should
get it PD close.
I believe you have a typo in your image. Part number is 260-10374, correct?
Post  gt1scca on Mon Jan 04, 2010 8:15 pm
Yea, yea...I'll fix it.
Post  Porch on Mon Jan 04, 2010 9:04 pm
Thanks, i was searching all over the web for the wrong part number! Embarassed Smile
Just ordered a clevis and i'm really looking forward to this mod! My trans is such a pain to shift some days, and 1st really puts up a fight unless i'm at a dead stop.
Shimming the clutch slave
Post  Arthropraxis on Fri Jan 08, 2010 8:26 pm
"If you are using a stock GM pressure plate that has the ratchet adjustment on the finger height you can put a .110 shim behind slave and it will help with engagement."
Found a thread on measuring to see if you need a shim
another with better pictures
I saw this posted on another forum. Is this a reasonable option to installing a larger clutch MC? I was planning on a new wilwood MC. If this works it would be easier and cheaper to stay with a new stock MC. Thoughts?
Post  Porch on Sun Jan 10, 2010 10:07 pm
It would probably work just fine! 968ls1 said that the shims would be a good alternative with a stock clutch though...i'm running the RH upgraded clutch.
For $100 i'm just gonna go with the upgraded master....
