Today at 8:27 pm by matt889
» Hello, Gentlemen.
Today at 7:43 pm by rawr
Today at 7:37 pm by Porsche951toLS3
Today at 7:17 pm by Porsche951toLS3
» alignment specs
Today at 12:53 am by sharkey
» Transaxle rebuild
VSS Setup on pre 85 cars
Post  msmoorenburg on Thu Dec 10, 2009 9:46 am
If your running a vss setup on a early car can you post some pics? Also if your running the cam gear setup what did you do to get to mount up?
msmoorenburg
Re: VSS Setup on pre 85 cars
Post  Porch on Thu Dec 10, 2009 10:24 am
Mine is not an early car, but i don't see why it would matter!
I drilled the center out of a 944 cam gear, then disassembled a CV axle and slipped it over the transmission side. I used some longer bolts to make up for the length. Made a little bracket for the VSS sensor, and done! I don't have pictures laying around, but if i think of it i'll get under there and snap some later...
Post  Admin on Thu Dec 10, 2009 10:50 am
There are some pictures of what the gear should look like on Vorsche944's gallery. The bracket he has is from RH, I had to bend the hell out of it to get it to read.....Typical right.....
and like Porch said the year model should not matter.
Post  948 on Thu Dec 10, 2009 11:27 am
scratch
Post  msmoorenburg on Thu Dec 10, 2009 11:39 am
948 wrote:scratch
wow i missed that and the search on (vss) didn't find that Embarassed
msmoorenburg
