» 4.8 Ls beast!
how much power can a N/A tranny take? EmptyYesterday at 5:07 pm by yamamtx
» RX7 oil cooler installation
how much power can a N/A tranny take? EmptyYesterday at 8:24 am by gwistrup
» PORSCHE 944 5th-0.68 , other gearbox parts GOT all you need!
how much power can a N/A tranny take? EmptyMon Apr 06, 2020 12:51 pm by Martynas
» 86 Porsche 944T LS1 swap begins
how much power can a N/A tranny take? EmptySun Apr 05, 2020 10:15 pm by smkn951
» Set of Wilwood big brake adapters
how much power can a N/A tranny take? EmptySat Apr 04, 2020 5:35 pm by scryfst
» RX7 Caliper swap adapters
how much power can a N/A tranny take? EmptySat Apr 04, 2020 5:21 pm by scryfst
» Ford Windsor engine swap
how much power can a N/A tranny take? EmptySat Apr 04, 2020 12:00 pm by haroldk
» C5 Transmission and TT?
how much power can a N/A tranny take? EmptyThu Apr 02, 2020 2:25 pm by spence
» looking for 944 v8 conversion manual
how much power can a N/A tranny take? EmptyWed Apr 01, 2020 3:28 am by spence
» 944 S2 - LS3 & T56 Conversion
how much power can a N/A tranny take? EmptyTue Mar 31, 2020 11:09 am by Slpr948
April 2020
6789101112
13141516171819
20212223242526
27282930
how much power can a N/A tranny take? Empty how much power can a N/A tranny take?
Post  kfsaleh944 on Sun Mar 15, 2020 5:25 pm
im planning on doing a 1JZ-GTE engine swap on my 944, since the 1jz is 280 hp stock, can the n/a tranny handle that amount of power without breaking the r&p?
kfsaleh944
how much power can a N/A tranny take? Empty Re: how much power can a N/A tranny take?
Post  Rich L. on Sun Mar 15, 2020 9:06 pm
I think your answer is 20% engine power and 80% driving style. I ran the original n/a transmission in my 944 with a 400 hp, 400 lb/ft LS1 on the track for 3 years, probably 15k miles. I ran it hard for long session on multiple day events. It did fine, no broken parts and no darkened fluid. The only reason I change the trans was to add an LSD. And that trans is working well too.
The trick here is mechanical sympathy. I never did a clutch-drop launch. I never pounded a shift. I never raced anyone stoplight to stoplight. All my usage was gentle launches, good warm-ups and then hard, full-throttle 3rd-5th gear running.
Post  kfsaleh944 on Mon Mar 16, 2020 7:58 am
Rich L. wrote:I think your answer is 20% engine power and 80% driving style. I ran the original n/a transmission in my 944 with a 400 hp, 400 lb/ft LS1 on the track for 3 years, probably 15k miles. I ran it hard for long session on multiple day events. It did fine, no broken parts and no darkened fluid. The only reason I change the trans was to add an LSD. And that trans is working well too.
makes sense, ill do my best to drive it with mechanical sympathy. thanks for the advice.
kfsaleh944
Post  Hotrodz of Dallas on Mon Mar 16, 2020 12:06 pm
But, not everyone is that lucky. I had a built 944 turbo that made 400 whp and 340 ftlbs torque. Installed an NA trans and it lasted about a week of running it on the highway racing other cars. Never dropped the clutch and never speed shifted. Probably raced someone 4-5 times total. It sheared all of the teeth off of the pinion gear and some off of the ring gear. While I know some people make them last awhile, most won't handle more than about 200 ftlbs of torque.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kfsaleh944 on Mon Mar 16, 2020 2:36 pm
it depends on the previous owner and how well he treated the car. But its a risk im willing to take since the car is terribly slow, and i cant stand driving a slow car.
kfsaleh944
Post  turbobob924 on Wed Mar 25, 2020 9:52 am
I had my buick V6 swap for a while which made 600ft lbs at the wheels
I blew up a couple transmissions due to
Sticky tires
Weak transmission mounts which caused bad shell hop
My current 86 turbo trans is still doing ok
Hope to get my LS swap done this year but it's all in storage now while I'm moving back to Ohio
turbobob924
turbobob924
http://www.turbo924.com
