» Early 944 Fuel Line Routing
Oil and Cooling question EmptySat Feb 15, 2020 4:35 pm by rallen130
Oil and Cooling question EmptyFri Feb 14, 2020 8:37 pm by VWTortuga336
» 1984 Porsche 944 with 1995 LT1 motor for sale
Oil and Cooling question EmptyThu Feb 13, 2020 12:47 am by jerry944
» Wizard Cooling Radiators!!
Oil and Cooling question EmptyWed Feb 12, 2020 12:32 pm by 87944turbo
» Oil and Cooling question
Oil and Cooling question EmptyWed Feb 12, 2020 6:01 am by gwistrup
» V8 Conversion Parts
Oil and Cooling question EmptyTue Feb 11, 2020 10:49 am by Chevota350
» Coil mounting pictures
Oil and Cooling question EmptyMon Feb 10, 2020 5:50 am by gwistrup
» 82 924 with AUX Audi V8.
Oil and Cooling question EmptyFri Feb 07, 2020 11:40 pm by Golten1986
» 14 Pin Connector - Check Please
Oil and Cooling question EmptyFri Feb 07, 2020 9:50 am by Hotrodz of Dallas
» 968 Swap Wiring Checklist/Questions
Oil and Cooling question EmptyWed Feb 05, 2020 2:39 pm by Kiltacular Jim
February 2020
3456789
10111213141516
17181920212223
242526272829
Oil and Cooling question Empty Oil and Cooling question
Post  gwistrup on Sat Feb 08, 2020 11:13 am
I have the modified Moroso oil pan installed on my Aluminum 5.3 conversion and I need to know which fitting on the pan is the "out" to the remote oil filter and which one is the "in" from the filter.
I purchased a radiator from TPC with the hose kit and installed it the other day and realized that there is no way to fill the cooling system from the original coolant reservoir the way I have it hooked up. The radiator has the upper and lower hose locations on the passenger side and the steam fitting and threaded fitting for the original Porsche fan control on the driver side. I have the Porsche fan control sensor threaded into the driver side fitting and installed the steam line on the nipple that was supplied with the radiator. The upper hose and lower hose are connected to the passenger side of the radiator. I also have the heater hoses connected to the heater core through a vacuum controlled valve. How can I use the lower fitting on the coolant reservoir (it's an N/A coolant reservoir so it only has one fitting) and connect it to the system? thank you, Gil
gwistrup
Oil and Cooling question Empty Re: Oil and Cooling question
Post  Hotrodz of Dallas on Mon Feb 10, 2020 9:55 am
You can use this in the upper radiator hose to tie into the coolant reservoir.
https://www.amazon.com/Dorman-627-006-Radiator-Hose-Connector/dp/B00DE95BLW
This pic shows the LS oil flow.
Oil and Cooling question Lsoilp10
Hotrodz of Dallas
Hotrodz of Dallas
Oil and Cooling question Empty Oiling and cooling
Post  gwistrup on Wed Feb 12, 2020 6:01 am
Thank you sir. I sure there will be more questions as my project continues. Gil.
gwistrup
