» 4.8 Ls beast!
944 Manual Brakes EmptyYesterday at 5:07 pm by yamamtx
» RX7 oil cooler installation
944 Manual Brakes EmptyYesterday at 8:24 am by gwistrup
» PORSCHE 944 5th-0.68 , other gearbox parts GOT all you need!
944 Manual Brakes EmptyMon Apr 06, 2020 12:51 pm by Martynas
» 86 Porsche 944T LS1 swap begins
944 Manual Brakes EmptySun Apr 05, 2020 10:15 pm by smkn951
» Set of Wilwood big brake adapters
944 Manual Brakes EmptySat Apr 04, 2020 5:35 pm by scryfst
» RX7 Caliper swap adapters
944 Manual Brakes EmptySat Apr 04, 2020 5:21 pm by scryfst
» Ford Windsor engine swap
944 Manual Brakes EmptySat Apr 04, 2020 12:00 pm by haroldk
» C5 Transmission and TT?
944 Manual Brakes EmptyThu Apr 02, 2020 2:25 pm by spence
» looking for 944 v8 conversion manual
944 Manual Brakes EmptyWed Apr 01, 2020 3:28 am by spence
» 944 S2 - LS3 & T56 Conversion
944 Manual Brakes EmptyTue Mar 31, 2020 11:09 am by Slpr948
April 2020
6789101112
13141516171819
20212223242526
27282930
944 Manual Brakes
944 Manual Brakes Empty 944 Manual Brakes
Post  jsnacker on Wed Jan 29, 2020 9:06 am
Hows it going everyone. I have an 83' 944 and just finished my swap. Currently running a stock MC with a renegade booster delete and pedal redrilled a bit higher up. The brakes are decent(think I need to re bled them) but looking for other options of manual setups. Was looking at the Wilwood 260-7563 tandem MC but wasnt to sure how people like them. More than likely staying with my stock NA brakes for the summer to get some seat time in the car. Plan on doing a full 944 turbo hub/suspension swap along with better brakes, maybe some big reds. Any input would be appreciated. Thanks!
jsnacker
944 Manual Brakes Empty Re: 944 Manual Brakes
Post  spence on Wed Jan 29, 2020 9:26 am
Ive used that wilwood master cylinder before with bigger calipers and it was scary. I would not recommend it. I now have mustang hydroboost and its so much better.
Post  sharkey on Wed Jan 29, 2020 12:17 pm
i tried that master and it was terrible. dont do it.
i found any tandem master cylinder to give terrible braking performance. i would wither go hydroboost, or a dual master cylinder and balance bar setup.
Post  jsnacker on Wed Jan 29, 2020 4:00 pm
sharkey wrote:i tried that master and it was terrible. dont do it.
Are you running a dual master cylinder? If so which one. Also what brakes
jsnacker
Post  sharkey on Wed Jan 29, 2020 6:30 pm
im running a dual master cylinder setup. its a wilwood vertical mount with the mini wilwood master cylinders, 3/4" front and 1" rear. i built my own firewall mount for it. the brakes are a mish mash, wilwood 12.19 x 1.25" rotors with lexus ls430 calipers up front, turbo rotors and rx7 front calipers on the rear. running carbotech xp-8 pads all around.
