» Early 944 Fuel Line Routing
Pedal Assembly - Which one? EmptySat Feb 15, 2020 4:35 pm by rallen130
Pedal Assembly - Which one? EmptyFri Feb 14, 2020 8:37 pm by VWTortuga336
» 1984 Porsche 944 with 1995 LT1 motor for sale
Pedal Assembly - Which one? EmptyThu Feb 13, 2020 12:47 am by jerry944
» Wizard Cooling Radiators!!
Pedal Assembly - Which one? EmptyWed Feb 12, 2020 12:32 pm by 87944turbo
» Oil and Cooling question
Pedal Assembly - Which one? EmptyWed Feb 12, 2020 6:01 am by gwistrup
» V8 Conversion Parts
Pedal Assembly - Which one? EmptyTue Feb 11, 2020 10:49 am by Chevota350
» Coil mounting pictures
Pedal Assembly - Which one? EmptyMon Feb 10, 2020 5:50 am by gwistrup
» 82 924 with AUX Audi V8.
Pedal Assembly - Which one? EmptyFri Feb 07, 2020 11:40 pm by Golten1986
» 14 Pin Connector - Check Please
Pedal Assembly - Which one? EmptyFri Feb 07, 2020 9:50 am by Hotrodz of Dallas
» 968 Swap Wiring Checklist/Questions
Pedal Assembly - Which one? EmptyWed Feb 05, 2020 2:39 pm by Kiltacular Jim
February 2020
3456789
10111213141516
17181920212223
242526272829
Pedal Assembly - Which one? Empty Pedal Assembly - Which one?
Post  87roadracer on Tue Jan 21, 2020 9:57 am
I have a 1989 944 and recently purchased a 2001 C5 LS1 motor complete with harness and ECU. Looking for advice on pedal assembly since it's a DBW. Must I use a one from a Corvette? What other vehicle pedals will work?
Thanks all in advance.
87roadracer
Pedal Assembly - Which one? Empty Re: Pedal Assembly - Which one?
Post  kevin924kevin on Tue Jan 21, 2020 11:19 am
I believe you should have to use vette pedal . Check wiring plug. My DBW uses the vette pedal.
Post  Hotrodz of Dallas on Tue Jan 21, 2020 5:27 pm
Kevin is correct. You will need the Corvette pedal. Ebay has some used pedals. New they are around $400
Hotrodz of Dallas
Hotrodz of Dallas
