Won’t go into reverse EmptyYesterday at 11:51 am by geegeesbits@gmail.com
Won’t go into reverse EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
Won’t go into reverse EmptySun Jan 26, 2020 4:51 pm by j7wolfe
Won’t go into reverse EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
Won’t go into reverse EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
Won’t go into reverse EmptySat Jan 18, 2020 7:15 am by Rothaus
Won’t go into reverse EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
Won’t go into reverse EmptyThu Jan 16, 2020 2:11 am by Golten1986
Won’t go into reverse EmptyTue Jan 14, 2020 2:48 pm by Gumby
Won’t go into reverse EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
Won’t go into reverse Empty Won’t go into reverse
Post  knucklehead12 on Sun Oct 27, 2019 4:28 pm
I am about done with my swap and my trans won’t shift into reverse. Shifts into forward gears fine. I can shift into reverse with the engine off but not with it running. It just grinds. Any help would be appreciated.
1989 944 base with a LS2 and a Turbo S2 trans.
knucklehead12
Won’t go into reverse Empty Re: Won’t go into reverse
Post  Hotrodz of Dallas on Mon Oct 28, 2019 8:46 am
Sounds like your clutch is not releasing far enough to get it in reverse. What clutch master cylinder are you using? Most of the cars i've built required the larger master that Kent sells to actuate the clutch enough.
Hotrodz of Dallas
Hotrodz of Dallas
Post  knucklehead12 on Mon Oct 28, 2019 8:58 am
I had the CNC 7/8” but could not get it to work. I just installed a 7/8” Wilwood compact master and it works great in forward. Just not reverse. It sounds like the clutch is not even pressed in at all when I try to go to reverse.
knucklehead12
Post  Hotrodz of Dallas on Mon Oct 28, 2019 11:33 am
Do you have any free-play in the pedal when its fully extended? If not, this could keep the master cylinder from filling completely. Need about 1/16 to 1/8" free-play
Hotrodz of Dallas
Hotrodz of Dallas
Post  knucklehead12 on Mon Oct 28, 2019 11:51 am
Yes there is a little play in the end fully extended. The clutch grabs about 1” or so off the floor.
knucklehead12
Post  spence on Mon Oct 28, 2019 12:16 pm
Did you check to the throwout bearing depth? (Ie: shims)
Post  knucklehead12 on Mon Oct 28, 2019 12:37 pm
Yes I shimmed the throw out bearing 1/8”
knucklehead12
Post  Hotrodz of Dallas on Mon Oct 28, 2019 1:40 pm
knucklehead12 wrote:Yes there is a little play in the end fully extended. The clutch grabs about 1” or so off the floor.
That's grabbing too close to the floor. Means you aren't getting enough travel for some reason. Clutch should start grabbing about a third to halfway off of the floor. What bellhousing and throwout bearing are you using?
Hotrodz of Dallas
Hotrodz of Dallas
Post  knucklehead12 on Mon Oct 28, 2019 1:45 pm
I am using the GM throw out bearing from TPC. Corvette C5 2 piece bellhousing. LS2 pressure plate and ACT GM015 pressure plate.
knucklehead12
Post  Hotrodz of Dallas on Mon Oct 28, 2019 2:02 pm
Hmmmm, You shouldn't have to shim that TO bearing at all. I've had one car that I had to re-drill the clutch pedal and move the rod down about 1/2". This was the only cure I could make work for that particular car.
Hotrodz of Dallas
Hotrodz of Dallas
Post  knucklehead12 on Mon Oct 28, 2019 2:07 pm
I have had a lot of issues like this. I will take the lower bellhousing off tomorrow night and see how much separation I am getting with the clutch fully engaged. I am at my wits end trying to get this done. One problem after another bit getting closer.
knucklehead12
Post  Hotrodz of Dallas on Mon Oct 28, 2019 2:19 pm
Yeah, It seems like every time I build one of these cars, it's always a different set of issues. No 2 cars are alike for some reason.
Hotrodz of Dallas
Hotrodz of Dallas
Post  knucklehead12 on Wed Oct 30, 2019 7:25 pm
So I measured the movement and the throw out bearing is moving about .6” but the pressure plate is only moving about .060”. I can spin the clutch but it seems like it needs a little more room to move freely. I am concerned that everything is right and I have a bad part. Any ideas?
knucklehead12
Post  spence on Thu Oct 31, 2019 5:00 am
Adapter alignment? Maybe the disk is binding slightly? Maybe try loosening the adapter bolts and starting the car, then tighten everything back up.
Post  knucklehead12 on Thu Oct 31, 2019 7:09 am
That is a good idea, I will try tonight. If it is in a bind at the top, I would not be able to see that from the bottom. Will let you know what i find out.
knucklehead12
Post  Hotrodz of Dallas on Thu Oct 31, 2019 9:48 am
spence wrote:Adapter alignment? Maybe the disk is binding slightly? Maybe try loosening the adapter bolts and starting the car, then tighten everything back up.
I have seen a few warped discs. That might be your issue.
Hotrodz of Dallas
Hotrodz of Dallas
Post  knucklehead12 on Thu Oct 31, 2019 9:53 am
I had the flywheel turned before installation, new disk (although could be bad as you suggest), and the pressure plate was one I had from another project with almost no miles on it. Will try the alignment tonight and see what happens, but certainly open to other ideas. Certainly appreciate the ideas.
knucklehead12
Post  knucklehead12 on Thu Oct 31, 2019 5:30 pm
Spence you are the man I put it on the lift. Loosened the adapter bolts and torque tube bolts. Lowered it a little to put upward pressure on the whole system. Tightened it all back up and it now shifts like it is supposed to. Thank you so much. So glad I didn’t have to take all that crap apart again. I owe you a case or beer.
knucklehead12
Post  spence on Thu Oct 31, 2019 5:33 pm
Nice. Glad you fixed it!
Post  Hotrodz of Dallas on Fri Nov 01, 2019 5:28 pm
That's awesome. Nice to be something easy for a change.
Hotrodz of Dallas
Hotrodz of Dallas
Post  matt889 on Sat Nov 02, 2019 8:20 pm
did you crank the engine with the bolt loose : O ? i wonder if that would work out !
matt889
Post  spence on Sat Nov 02, 2019 11:46 pm
It centers everything and let's everything find where it wants to be. And yes, it works. Relax Matt, you scared buddy? Laughing
