944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyYesterday at 11:51 am by geegeesbits@gmail.com
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptySun Jan 26, 2020 4:51 pm by j7wolfe
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptySat Jan 18, 2020 7:15 am by Rothaus
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyThu Jan 16, 2020 2:11 am by Golten1986
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyTue Jan 14, 2020 2:48 pm by Gumby
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) Empty 944 ls1 swap brakes and transaxle problems.. (Legal in Sweden)
Post  gunnarsson on Sun Oct 20, 2019 5:28 am
Hi!
I live in Sweden and to make a ls1-swap road legal I need to change both the brake system and the gearbox. The problem is that I can't use parts from the model series, which means that I cant use 924, 951 or 968 brakes or transaxles.
I'm planning of using cayenne brake calipers and rotors. Is this the best or is there anything better?
And the hard part.. The gearbox.. I'm thinking about using the boxster transaxle. I could use Audi 01E gearbox since it coming from another model. Or is there an even better alternative? I want to make the swap as smooth as possible, so as easy as possible would be good.. Very Happy
Thanks for the help!
Andreas
gunnarsson
944 ls1 swap brakes and transaxle problems.. (Legal in Sweden) Empty Re: 944 ls1 swap brakes and transaxle problems.. (Legal in Sweden)
Post  sharkey on Sun Oct 20, 2019 1:40 pm
from what i understand the boxster transaxle is an 01e.
i would use the audi 01e as thats now a proven swap. that or the corvette transaxle, but thats a lot of fab work.
Post  gunnarsson on Wed Oct 23, 2019 6:57 am
Wonderful! I will start looking for a 01E gearbox!
I think that I will go for the ls430 calipers instead of cayenne, only need to see which hub to use, got n/a hubs and think I need the turbo ones.
Another question, I'm thinking of using a lt1 instead. Is there much difference in mounting between lt1 and ls1?
gunnarsson
Post  sharkey on Wed Oct 23, 2019 2:12 pm
the problem i ran into with the ls430 calipers is the lack of pad selection for them. the only off the shelf "upgrade" pad for them is the ebc redstuff, and i found they didnt work well in my setup (i am manual brake). i ended up switching to carbotech xp-8 pads and it greatly improved braking performance, however being these are considered a "track only" pad you may not pass whatever inspections you have to go through.
i would recommend going with a porsche caliper so you have better off the shelf pad selections.
what lt1 engine are you looking at? gm has used the lt1 designation multiple times in the last 40 years. there is the gen 2 350 from 92-98, and the 2014+ gen 5 engine. either way, ls style mounts wont bolt to either of them, and the clutch and flywheel situation is different as well. id recommend against the 92-98 lt1, while they can make good power they are a pain to tune, they are around 100lbs heavier than an aluminum block ls, and the swap parts are not as readily available anymore.
Post  gunnarsson on Wed Oct 23, 2019 3:22 pm
This is why I hang out in forums like this! This information is hard to find elsewhere!
Then there will be Porsche calipers. As you say I’m not gonna get passed the inspection with racing pads...
And then I ditch the lt1. It is hard to find one here also, much easier with the ls1 Very Happy It was the 92-98 versions I was looking at.
Andreas
gunnarsson
