Sensor compatibility EmptyToday at 9:51 am by kevin924kevin
Sensor compatibility EmptySat Nov 16, 2019 9:00 am by j7wolfe
Sensor compatibility EmptyFri Nov 15, 2019 6:34 pm by Hey_Allen
» LS engine & Trans "upfront", Mustang IRS in the "rear"
Sensor compatibility EmptyMon Nov 11, 2019 5:59 pm by sparkydog
» WTB: Trailing Arm Bushings
Sensor compatibility EmptyMon Nov 11, 2019 9:18 am by Hotrodz of Dallas
» 82 924 with AUX Audi V8.
Sensor compatibility EmptySun Nov 10, 2019 2:35 pm by Golten1986
Sensor compatibility EmptySun Nov 10, 2019 5:13 am by superman22x
» Introduction/CA-SMOG '86 turbo
Sensor compatibility EmptySat Nov 09, 2019 8:29 pm by pormgb
» 944-LT1 LS3 Conversion
Sensor compatibility EmptySat Nov 09, 2019 7:49 pm by Ordie792002
» Lexus BBK Big Brake Kit
Sensor compatibility EmptySat Nov 09, 2019 6:19 pm by Red944ls1
November 2019
Sensor compatibility Empty Sensor compatibility
Post  gwistrup on Mon Oct 14, 2019 8:05 am
I have a 2003 LM4 5.3 out of a Trail Blazer and a wiring harness with PCM from a 1999 F body LS1 5.7 that I am installing in an '88 944. I have all of the major components to do the swap and now I'm looking for some of the smaller items. The LS1 intake from the F body has the IAC, MAP, and TPS sensors on it and I believe I can use those sensors with my '99 PCM. Will the knock sensors, cam, crank, and coolant temperature sensors from the LM4 5.3 work with the '99 PCM? What MAF sensor should I use? The LM4 is a 24X crank sensor. Thanks, Gil
gwistrup
