SOLD: LS1 Swapped 1985.5 944 EmptyToday at 9:51 am by kevin924kevin
SOLD: LS1 Swapped 1985.5 944 EmptySat Nov 16, 2019 9:00 am by j7wolfe
SOLD: LS1 Swapped 1985.5 944 EmptyFri Nov 15, 2019 6:34 pm by Hey_Allen
» LS engine & Trans "upfront", Mustang IRS in the "rear"
SOLD: LS1 Swapped 1985.5 944 EmptyMon Nov 11, 2019 5:59 pm by sparkydog
» WTB: Trailing Arm Bushings
SOLD: LS1 Swapped 1985.5 944 EmptyMon Nov 11, 2019 9:18 am by Hotrodz of Dallas
» 82 924 with AUX Audi V8.
SOLD: LS1 Swapped 1985.5 944 EmptySun Nov 10, 2019 2:35 pm by Golten1986
SOLD: LS1 Swapped 1985.5 944 EmptySun Nov 10, 2019 5:13 am by superman22x
» Introduction/CA-SMOG '86 turbo
SOLD: LS1 Swapped 1985.5 944 EmptySat Nov 09, 2019 8:29 pm by pormgb
» 944-LT1 LS3 Conversion
SOLD: LS1 Swapped 1985.5 944 EmptySat Nov 09, 2019 7:49 pm by Ordie792002
» Lexus BBK Big Brake Kit
SOLD: LS1 Swapped 1985.5 944 EmptySat Nov 09, 2019 6:19 pm by Red944ls1
November 2019
SOLD: LS1 Swapped 1985.5 944 Empty SOLD: LS1 Swapped 1985.5 944
Post  robschwieb on Mon Sep 16, 2019 12:25 pm
It hurts to make this post but I'm selling my swapped 944. It's always been about the "challenge" or "project" for me and once I'm done with something I quickly loose interest. Having a newborn and many cash hungry projects around the house are also to blame.
Anyway, details on the car can be found in my build thread here: [You must be registered and logged in to see this link.]
Quick specs:
-1985.5 944
-1999 LS1 out of a WS6 with 80k miles
-M030 sway bars
-250lb front springs
-28mm rear torsion bars
-Koni sports front and rear
-Turbo 9U trans (LSD, no cooler, NA 5th gear swap)
-TPC trans reinforcement plate
-Drilled & slotted rotors front rear
-Performance pads
-Euromeister 17x8 & 17x9 wheels
-Sumitomo HTR Z III's 225x45R front & 255x40R rear
-New ball joints & tie rod ends
-Re-manufactured steering rack
-Re-built calipers
-Custom aluminium 951 radiator
-Ford Hydroboost with original 944 master
-Power steering cooler
-Custom 3.5" intake
-LS6 intake manifold
-Walbro 255 fuel pump
-42lb injectors
-243 heads
-TSP 224R cam (.600/.600 with 114 LSA)
-PAC 1219 springs
-COMP Cams trunnion retrofit
-LS7 lifters & trays
-New oil pump
-New water pump
-New timing chain set
-New seals and gaskets all around
-New dash cover
-New speakers and head unit
-Custom 3" exhaust (sounds amazing without being obnoxious)
The swap has about 1,200 miles on it and I've only had two problems during that time. One was overheating due to a bad coolant reservoir cap and the other was a failed power steering rack due to a cheap rebuild. New cap has kept temps perfect even on hot days in traffic and the AutoZone steering rack was replaced with one rebuilt by RackDoctor.
What some might consider "cons"
-No A/C. I left the stock condenser installed with hopes of finishing the system last spring. I never got around to it and don't plan to. I will include the GM A/C compressor and bracket if you are interested in completing this.
-No windshield washer fluid system (took up too much space)
-Paint isn't in the greatest condition.
-Rear hatch glass needs resealed (like most 944's)
-Still needs an actual alignment. I did a home alignment and it works for now.
Asking $14,000 OBO
Located in Northeast Indiana
Contact me here via PM or text me @ 419-699-8811 (please no calls).
Rob
robschwieb
robschwieb
SOLD: LS1 Swapped 1985.5 944 Empty Re: SOLD: LS1 Swapped 1985.5 944
Post  turbobob924 on Tue Sep 17, 2019 5:24 pm
Nice looking car
Sent from Topic'it App
turbobob924
turbobob924
http://www.turbo924.com
Post  robschwieb on Fri Oct 25, 2019 9:45 am
Price drop! $14,000 OBO
robschwieb
robschwieb
Post  robschwieb on Wed Nov 06, 2019 9:36 am
SOLD
robschwieb
robschwieb
