CSR Thermostat Housing Info and Another Alternative
+4
Bluemach1
Max Energy
8 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: CSR Thermostat Housing Info and Another Alternative
Thanks Mike. I'm glad I'm not the only one to run into this problem. I,m going to make a whole new adapter plate that steps the Truck T-stat down to properly close the port and circumference a snap-ring grove to keep it locked in place.
CSR Thermostat housing.
Hope I have finally found out how to post pictures.
Here is my modified water outlet with the CSR housing.
Stock T-Stat housing
Here's a clearance shot of the stock housing, before I cleaned up the hose end.
[img][You must be registered and logged in to see this image.][/img]
Hey 87-944S, where did you get that hose from? I went all over A-zone' back wall of hoses and nothing had a good enough bend to be just right. Thanks
I used and Advanced Auto Parts D71500 for the lower hose. It was a tight fit between the radiator and T-stat, so I cut it in the middle and used a piece of tubing to extend the hose. I used a section of this hose, the angles were perfect. I'm using an all aluminum Turbo radiator I had Griffin make without the Porsche fan switch bung, since I'm using the GM computort to control the fans.
Page 2 of 2 • 1, 2
Page 2 of 2
