Head light conversion buckets
+16
968gene
Tetzuoe
944v8inDFW
ffmedic
Vorsche944
Oldschool350
Phatjimmy
coctostan
Johnny Johnny
golfduke
20 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: Head light conversion buckets
good stuff. Keep the information coming!
If you have Hella part numbers too.....
Part Numbers
Here they are;
Low Beam Hella HL68137
High Beam HL21540
I also ordered the mounting plates, the mounting plates are steel and make it easier to mount the lights in the fiberglass buckets. The lights come with adjusters. They also carry the connectors for the H9 bulbs. I bought these from [You must be registered and logged in to see this link.]
High Beam HL21540
What was the over all cost for the 4 lights. I see that they now have the High/ low in one housing, although it is extensive.
I would be wary of those "shutter-type" lenses. After driving a 2000 Celica GTS with basically the same design, you can't see $#** at night on low beam. The light output is blocked at the top of the lens, and the projected beam looks "flat".
You have to run the driving lights with them to be able to see past the nose of the car...
gt1scca- Posts : 795
I think about $400 for all four lights, mounting plates and H9 connectors.
[You must be registered and logged in to see this link.] Will these fit into the 944hybrids.com buckets ?
Phatjimmy- Posts : 17
What kind of mounting bracket for universal 4x6 lights would you guys recommend?
flosho- Posts : 5
I was debating between buying your uncut buckets and the ones with the mounting hardware. I found some "narva 165x100 open back mounting hardware for $25 a piece but if they are the same kind you use I might as well buy it all from you.
I'd post the link but I'm on my phone.
Do the buckets for $255 come with the headlight housings too?
flosho- Posts : 5
The $255 set come with the buckets and all hardware needed. minus the lens covers and bulbs.
The headlight baskets that I use are factory one's that I modify,
Here are the mounts I was looking into:
Can you post a picture of everything that is included in the $255 price? I'll probably just go that way since I wont be saving much (if any) money doing it myself...
*edit, I looked back and see you posted a decent shot of the mounting for the head light.
flosho- Posts : 5
Page 4 of 4
